SOURCE: My Toshiba Satellite L455-S5975 will
There is probably a short or your version of your laptop crashed. You might want to take it in and get disgnostics run on it. Hope this helps!!
Please rate and comment - Thank You
SOURCE: Toshiba Satellite L455-S5000 turns on
Try external monitor, if it works then more likley the backlight inverter or the lamp is bad.
see www.insidemylaptop.com for example.
http://www.sparepartswarehouse.com/Toshiba,Satellite,L455-S5000,PSLY0U-03F02F,Laptop,Inverters.aspx
Please leave rating if it helps.
SOURCE: my toshiba satellite l455 won't start up it
click on F2 and that will take you to the Bios setup, check that your hard drive and Ram (Memory) are both online if all is ok and no problems press F12 it might take you to a diagnostic screen prompting you to perform a diagnostic test, if so do the tests and write down any errors given, if there is not diagnostic tool you might get the options to restor factory defaults this option will reset your computer to its original state and you will lose all your data. Another option if you have the operating system's cd (windows xp, vista etc) from the bios (F2) change the boot sequence to cd (just click on Cd/DVD Rom)only and reboot, windows will ask you if you want to repair, if all your hardware is ok and you should be able to solve the problem good luck and all the best
SOURCE: toshiba satellite L455-s5046
If you are looking for the device drivers for your model Toshiba then -
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
