Question about SanDisk Sansa e250 MP3 Player
How do I format my Sansa e250?
I'm so confused. How do I reformat my Sansa mp3 player? I can't switch it on, because it does this weird restarting thing and the menu will not come up at all. It shows the SanDisk logo and then the whole screen just goes white, and it does it over and over again. I know someone else had the same trouble... but I don't know how to reformat it :( how can this be done?
  • 5 more comments
  • Holly  Shad
    Holly Shad Jan 27, 2007
    It doesn't recognise the MP3 player because the MP3 player won't stay switched on.
    I've tried reloading the firmware too but that doesn't work either.
    I'll probably just email tech support.
    Thanks anyway :)
    Holly
  • Anonymous Dec 15, 2007
    i want to know how to fomat
  • Anonymous Feb 21, 2008
    my sandisk sansa m240(1GB)MP3 Player will switched on but it just show "finilizing update" on the screen and just stay there it will not continue to operate and the computer will not recognize if i connect it to my computer.what probable solution should be made?
    i have the same problem
  • esmouel Dec 10, 2008
    how did u fix your sansa after this a"" hole try
  • Anonymous Mar 18, 2009
    my screen reads - load main imagefailed - switch to recovery mode
  • durairajansp Apr 06, 2009
    My Sansa have some corrupted files in the disk, i couldnot play or delete .
    Can you please help , how to do that ?
This worked for me... Hope it works for you as well
*Disconnect the device, turn it on
*Go to Settings > USB Mode > MSC
*Connect the device
* Open up My Computer
*Under the heading "Devices with Removable Storage"
Look for Sansa E250 (Removable Drive) - Note: this heading
"Devices with Removable Storage" applies to the "Arrange Icon By: Type" , option in My Computer Window
* Right-click on the E250 and choose format
*Click "Start" and agree to the format
Posted on Jan 09, 2008
  • 1 more comment
  • Alicebro Feb 04, 2013
    Format Sd card will make all data lose. If you want to recover data, Tenorshare Photo Recoveryhttp://www.any-data-recovery.com/product... could help
  • Lily Feb 14, 2013
    I think you may try format memory card recovery tool
  • Lily Feb 14, 2013
    try this memory card photo recovery softwarehttp://www.asoftech.com/apr/
  • 102 Answers
You can remove the memory card from Sansa e250 and then connect memory card to computer with a card reader, you can then format it from computer, if you need to recover files, you can use this file recovery software named asoftech data recovery
http://www.asoftech.com/adr/
Posted on Feb 14, 2013
I found a nice way to format it without risking any problem
1) Turn the Sansa off and lock it
2) Hold the RECORD button while plugging it to the USB
3) Release the RECORD button once you see "Welcome to Recovery Mode" on the player's LCD.
4) Go to my computer there would be a new removable drive named 16MB-FORMAT open it.
5) While in this drive right click... in the contextual menu go to NEW and choose TEXT DOCUMENT
6) Name the document sansa.fmt... Unlock the player before Unplugging it.
It will reformat itself since whenever there is a file or folder called sansa.fmt in this drive it is supposed to do that.
Good luck
Posted on Jan 01, 2010
This really works!!
Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Once you have downloaded the file, please follow these instructions.
1) Double click on My Computer so that you can see it on your screen.
2) Turn the player off.
3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button.
5) Extract the files from this file by clicking right on the .exe fileand selecting Extrac files
  1. when you are in, there are 2 folders open the one that is named SKU_E then you´ll see 2 files copy them and drag them to the device that is named 16MB FORMAT.
  2. then wait for 5 seconds and then turn it on.
Posted on Jun 25, 2009
For everyone who is going to use these solutions DO NOT USE THE 7 STEP SOLUTION!!!! IT IS A PIECE OF **** AND SCREWED THE HE** OUT OF MY SANSA. WHOEVER PUT IT ON HERE EITHER HAS NO IDEA WHAT THEY ARE DOING OR IS A GENUINE A**HOLE.
Posted on Jun 14, 2008
Do not use the 7 steps suggested by "guest" ITS A SCAM. it ruined my mp3 player
Posted on Sep 18, 2007
  • 4 Answers
If you are using a Mac running OS X you can do this:
Turn off the player.
Slide the lock swith to right until you see the orange strip.
Connect the usb cable to the computer. Do not connect it to the player.
Press the start (menu) button. Keep it pressed. The player will start up. Wait until it shuts down.
Connect the usb cable to the player. The player will start up and in a few seconds its icon will appeat in the Desktop.
Go to the Disk Utility in Applications->Utilities. You will see the player listed. Format it as MS-DOS FAT 16. Quit Disk Utility.
Drag the player icon to the trash. This will unmoount it.
Disconnect the usb cable from the computer. You will see a progress bar saying "Refreshing database". Wait until this process finishes.
Slide the lock icon to the left. The orange strip will disappear. Press 'menu' to turn off the player.
Turn it on again.
(If you have a microSD card, remove it before doing the steps above.)
Good luck
Posted on Dec 10, 2009
http://www.sandisk.com/Assets/File/Downl...
the above link is not working boss...
the page is not found....now what?
i am extremely tiered with this sansa.please let me know what to do
Posted on Aug 19, 2009
Ok first thing you take it back and ask for a new one i had the same thing and its a real ***** dont waist your time you have a warenty for a reason
Posted on May 26, 2008
Solution #4 WORKS!!!!!
MY PLAYER WAS ALL MESSED UP SO I FORMATED IT, THEN IT DIDNT TURN ON, I SPENT A FEW HOURS SEARCHING THEN FOUND THIS AND IT WORKED :D
THANKS!
Posted on Mar 14, 2008
MafiaMandee
u are the besttt
Posted on Feb 14, 2008
I had ruined my e250 doing it the way the "guest" above had noted. Note, the only reason why is because there are TWO files needed to format the Sansa e250. Contact their Tech Support via their website, once you register the Serial Number of your Mp3 player they will send you the required files. Hope that helps :)
Posted on Nov 14, 2007
The soluation is to turn off the hold button and then plucg it in.
Posted on Jun 17, 2007
CAPS LOCK IS CRUISE CONTROL FOR COOL o0ace0o
Posted on Oct 04, 2008
For all those people who are having problems with the 7 steps, then pay attention and do it properly. that information hasnt just been pulled from nowhere, that is the actual way of fixing software problems, advised by the sansa tech team. if it doesnt work, then do something else, but dont come in here insulting the people that are trying to help you. stupid fucks
Posted on Aug 04, 2008
Noob
Posted on Jul 28, 2008
    Problem Solver:
  • 8 Answers
I've actually used "Guest" 7 step advice on about 6 different software related issues with a 100% success rate. It has worked great for me.
Posted on Feb 27, 2008
I had this problem and asked tech support.. heres the solution. hope this works Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop. http://www.sandisk.com/Assets/File/Downloads/firmware/rhapsody-1.0.1.47.zip Please do the following steps to install the firmware in your computer: Unzip the downloaded zip file and extract the file pp5022.mi4. Once you have downloaded the file, please follow these instructions. 1) Double click on My Computer so that you can see it on your screen. 2) Turn the player off. 3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange. 4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button. 5) Drag and Drop pp5022.mi4 from your PC to the 16MB Format folder. 6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left. 7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Posted on Mar 29, 2007
    Problem Solver:
  • 3 Answers
When you connect to the computer does Windows Media player recognize the MP3 player? If so you can reformat in Windows Media player. Or you can try reloading the firmware. If the Sansa Updater says that you have the lastest firmware download the firmware manually and then run the software. In addition, tech support is fantastic with Sansa give them a call or e-mail. Best Regards, Keith
Posted on Jan 27, 2007
WARNING
DO NOT FOLLOW THE PERSON IN SOLUTION #3 "GUEST" WITH THE 7 STEPS CAUSE IT WILL ONLY DO MORE DAMAGE TO YOUR SANSA. IVE SPENT THE WHOLE 8 HOURS TRYING TO FIX IT BECAUSE OF THAT FREAKING "GUEST" WITH THE 7 STEPS HOPE HE DIES.THANKFULLY WITH MY EXPERTISE I WAS ABLE TO FIX IT BUT WITH NO HOPE GETTING BACK MY RADIO FEATURE MAYBE ILL TRY IT TOMORROW GOT TO SLEEP.IVE ALREADY WARNED YOU GUYS
Posted on Feb 02, 2008
How do I reformat my sansa E250
just connect it to computer. it iwl be shown as a external storage device. you can just right click and give format.
Jul 27, 2009 | SanDisk Sansa e250 MP3 Player
Reformatted sansa e250 need help
When you format it, it deletes everything on the player. You'll just have to put everything back on it.
Jun 20, 2009 | SanDisk Sansa e250 MP3 Player
My sansa is spazzing out
Go to settings - USB Mode -- msd; and make sure the port on your computer is a USB 2.0 port.
Jul 05, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
I cant delete videos from my 4 gb sansa
change it to fat32 and format it. it should work
May 16, 2008 | SanDisk Sansa e250 MP3 Player
I can't delete songs!!!
Reformat the drive on your Sansa. Open My Computer then right click the drive that corresponds to your Sansa and choose format. It will be the one that says "removable drive". This usually works, just make sure you keep a backup of all your music in case this happens again.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Broken
hi try formating the mp3 then check if it still has the music.
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
Regarding writing
Reformat in Windows Media Player, and never use Real to sync
Apr 13, 2007 | SanDisk Sansa e250 MP3 Player
Weird music files on my Sansa e250 media player
Reformat your Sansa via My Computer. Right click on your Sansa while in my computer, and then FORMAT. Please understand that this will delete ALL of your files. You will have to resync any pictures or music. I had to do this in MTP, AND MSC mode individually to get rid of those pesky items.
Dec 03, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
17,669 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
