I want to change the channel of my router but i don't know how to. please help
Hi Felix,
Try these steps and let me know if it works.
Step 1 : Type http://192.168.0.1 on the address bar of internet explorer
Step 2 : Login to the router setup by typing the default password admin
Step 3 : Click wireless settings on the left side.
Step 4 : Click Manual Wireless Network Setup
Step 5 : Under Wireless network Settings Uncheck the option Enable Auto Channel Scan
Step 6 : Select the wireless channel you need
Step 7 : Click Save Settings.
SOURCE: D Link DIR-300 - Connection was Reset - Unable to set up router
press reset button for 10 seconds then all settings are defaults.
you can access your router witrh following link
http://192.168.0.1 or
http://192.168.1.1
SOURCE: Signal strength bad between PS3 & D-LINK DIR-655 Wireless Router
Things to try:
1. Swapping the router from mixed mode to G only.
2. Raise up the wireless router higher in the room.
3. Move the router closer to the ps3 or the ps3 closer to it.
4. Run ethernet cable to the ps3 from the router. (clunky but 1ms ping times to the router does make seem worth it.)
5. Put the ole warhorse of a linksys back in and hope for store credit on the dlink. As it seems to have been working for you.
To answer your question:
Currently most things have built in G class wireless antennas. As such they prefer G and the N router eats into the G's spectrum. Not bad but some bleeding of channels is just going to happen and as such N class things will love the N router but the G class have to suffer a bit.
SOURCE: DIR-600
If you have a space where you insert the port number it wont work to save your settings
SOURCE: Please help.... I have just purchased a dlink
For setup, you need an Ethernet cable connection to the router, WLAN needs to be configured first before you can use it to administrate the router.
Quick installation guide is here: ftp://ftp.dlink.de/dir/dir-600/documentation/DIR-600_revb_qig_multi.pdf
The default user name is "admin" with empty password.
If you suspect the settings are not at factory defaults, press the reset button at the rear for 20 seconds with the router powered on.
SOURCE: HI , i want to reconfigure
admin or password...
try both in all combinations for both username and password...
for example...
username: admin
password: admin or password
