No power to washer but outlet works
Went to turn on washer it would not power up. I checked the outlet and there is power to it. Any ideas on how to fix it?
  • 33 Answers
Make sure the water is turned on to the unit. Sometimes there is a fuse inside the machine if it is an older maytag unit.
Posted on Dec 01, 2008
My washer will not turn on
Power cut may have blown fuse . If not check mains filter. If that's ok then mother board may be damaged
Aug 08, 2014 | LG WT5101H Top Load Washer
Why wont my Splendide washer/dryer wont turn on?
check outlet for power if ok bad switch or transformer make sure on 120 volts
Jun 13, 2014 | Splendide Washing Machines
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
Power went off now my washer will not work
First thing to check is for power at the outlet--plug a working lamp in. If no light, find the laundry room breaker in the house electrical panel--push off, then on. Recheck with the light. If ok, try the washer. Hope this helps!
Sep 07, 2009 | Washing Machines
46462 unit will not turn on
Hello anava214
Welcome
You said, your washer will not power up . Even the lights on the display panel are not turning on . And you have checked that the power outlet works.
Did you unplug the washer for 5 minutes and then plug it back in?
This can resets the system.
How old is the washer?
Oct 05, 2008 | Kenmore 46462 Front Load Washer
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer works- washer doesn't
Check the outlet to which you connect your washer; check the plug of your washer, wires, fuse.
May 31, 2008 | GE WSM2420T Top Load Stacked Washer /...
Machine is dead
hard to diagnose ths one but i would start by verifying power in to all the pc boards (there is 2)
Sep 24, 2007 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
