Question about Brother MFC 8820D All-In-One Laser Printer
Power surge - how to repair??
I recently had a power surge and knocked out my printer. can the ac power adapter be replaced for this printer?
  • Brother Master
  • 1,113 Answers
Power surges on these can take out the main board (unnumbered), modem(3), and power supply(4), approx 150 each.
Posted on Dec 28, 2007
SOURCE:
Is my wii dead?
replace power supply .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Sep 30, 2015 | Nintendo Wii Console
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Unit will not come on-power ok ac to dc adapter ok
Great job on checking the power from AC to DC adapter. Also, make sure to plug the printer straight to the power outlet in the wall, bypass any surge device or power strip. Unplug and replug the power adapter in the printer, make sure it's properly secured and in the right position in the slot. Press the power button if needed. If this doesn't help at all, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
Jul 01, 2010 | Lexmark X5495 Printer
The wii was unplugged inadvertantly, once plugged back in it won't turn on...red light does not come on...what are the possible reasons ...cable had gone out earlier in day and had to reboot
You most likely need to reset the AC adapter.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. You plug it back in, the power comes on, but it appears dead. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up, and it should work.
Dec 08, 2009 | Nintendo Wii Console
Broken wii
You need to reset the AC Adapter. It's a common issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 23, 2009 | Nintendo Wii Console
My wii won't power up. I am not sure what is wrong, but it won't turn on.
I just posted this somewhere else where this was asked, but I'll post it here too so it helps other people.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Aug 05, 2009 | Nintendo Wii Console
How to reset ac power adaptor on the Wii
Try unplugging your wii console's AC adapter for your wall outlet to reset it didn't correct this, then if you can, try using/borrowing another AC adapter and see if perhaps the power surge blew the fuse that is inside of it.
But if your Wii console still will not power up, then you will have to call Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number to set up a repair, as the power surge may have damaged something in your console.
Jun 26, 2009 | Nintendo Wii Console
No Power to HP All-In-One 7310xi
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab102
Jun 18, 2009 | HP Officejet 5610 All-In-One InkJet...
C4180 Won't Power On
Make sure the plug is all the way into the AC adapter. Then, you will need someone to verify the output of the AC adapter. You should have a 16VDC and a 32VDC output from the adapter. If that is good, you have an internal problem with the printer. If the output voltage(s) are missing you will need to replace the AC adapter.
Here are the specs:
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
  • HP part# 0957-2146 Call 1-800-227-8164 for availability.
  • Nov 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Brother MFC 8820D All-In-One Laser Printer Logo
    690 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
