I' m haveing a problem with my laptop lg e300 it won't let me get anywhere i try loading it in safe mode normal all that happend is a screen pops up and sais "the application failed to initialize properly (0xc0000006). click ok to terminate application
  • Richard Lilja
    Richard Lilja May 11, 2010
    More info is needed as to what works and what doesn't work after getting the message "the application failed to initialize properly (0xc0000006). click ok to terminate application".
    Do you get any "Blue Screen of Deaths" showing up?
  • 51 Answers
The problem is your window may be currupted or may be virus.reinstall your window problem will be solved
Posted on Dec 05, 2008
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
Won't find solution to problem and start up
While booting up you should try holding f8 right after the manufacturer splash screen the select safe mode with networking once in there you will want to restart the computer if all is well it will boot into windows! hope i could help =]
When i turn it my eee pc on it pops up to where it says windows and thats as far as it will but it will only load up in safe mode
Try restarting your notebook and hit the "f8" key after you see the first screen come up. Keep hitting the F8 key until you see a menu that says "start in safe mode" start in safe mode with networking......
Start in last known good configuration....Start windows normally.
Try using Start in last known good configuration.
Hopefully, that will solve the problem that is hanging up your windows from starting.
Brian
Mar 01, 2010 | ASUS Eee PC 1000H Laptop
I have a LG E300 notebook and once i switch it on it responds for a while and then freezes, then changes to blue screen saying: Problem occured so windown has shut down to prevent damage: After few hours...
It can be caused due to any driver clash or antivirus . With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Jan 26, 2010 | LG X-Note LM50 Notebook
Green flickering squares when i turn on my laptop
Something's wrong with the display driver or the display card. You can try opening up the T61. The contact on the display chip or the display connector is probably corroded. Try pressing them a bit (not to hard). if it's the display connector, try removing it and placing it back. I've had this problem before with some other notebook. It's ok when in safe mode because safe mode doesn't use the higher display functions.
Oct 11, 2009 | Lenovo ThinkPad T61 Notebook
Black screen nothing loading
One of your driver is acting up. start in safe mode, disable one of the drivers (DVD or whatever) then close and try to start normally. If the PC starts then reinstall the driver.
Aug 10, 2009 | Lenovo 3000 C200 Notebook
Freezing in 'safe mode'
Have you tried accessing the bios to set boot order? It may be trying to load from the hdd before the optical/usb drive.
During the flash screen, press F2 (though it can vary by maker) and change your boot order to load the USB drive first.
Hope this helps!
Apr 29, 2009 | ASUS Eee PC 1000H Laptop
Compaq pesario C300 not starting
Have you tested your harddrive to make sure it's working properly,or you are maybe missing ntldr
Dec 10, 2008 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
105 people viewed this question
Alun Cox
David Payne
David Payne
