Question about Reddy Heater-30-55,000 BTU Variable
Works in short spirts
I have a reddy heater 170c that switches on,heats up for approx.2-3 mins,then shuts down and blows a puff of smoke.i will switch it off,wait a few minutes and the same thing happens.i have heard many remedies to the problem.i have cleaned the fuel tank and even added a fuel filter.someone recommended a thermostat.please help me
  • 1 more comment
  • fardfollower Dec 09, 2008
    IM BAAAAACK!
    SORRY
    im baaaack!
    my ready heater is still acting up.i finally got it and cleaned the photo cell.as i tried it,it doesn't seem to be drawing any fuel through the line.i have one of those clear inline filters so i can see the fuel.i pulled the fuel line out of the tank and put it in some fuel in a small can.i switched it on 3 or 4 times but i never got it to draw up any fuel.i would be so so so grateful to get this going.i know its a minor problem and as soon as i get so frustrated and toss it,the fix is gonna come to me.thanks in advance for any help and for those who are making suggestions,peace!!
  • Joseph Lillie
    Joseph Lillie May 11, 2010
    Good day and welcome to Just FixYa.
    Can I have the full Model Number, Please.
    I do not think it is your thermostat if the unit is coming on.
    Please post back.
Roger Becht has the best (and cheapest) solution to try first. Bend a Q tip to reach the photo cell with out removing it and swab it out. It didn't come back filthy but I bet it had just enough dust on it to cause it to malfunction. This procedure fixed mine with the same problem. Also, I bought a low pressure gauge and checked the pump pressure, and it was 5.5 psi instead of the specified 5.1. They say that's pretty critical.
Posted on Dec 02, 2008
There is a photo cell in many heaters to detect the light of the flame. Try cleaning or replacing the cell. If it can't see the light it will shut down the unit.
Posted on Dec 01, 2008
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
Nov 01, 2008 | Heating & Cooling
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
110 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
