No matter were i adjust the thruster jets the cleaner doesn't want to climb out of the deep end. just goes around in circles in the deep end
SOURCE: i got a legend platinum poll cleaner this week and
The first thing I would check is the swivels in the hose line. Make sure all of them spin, it not then replace that swivel. You may also want to check the length of the hose, if it was not adjusted to the proper length, this could be the issue also.
Another place to check is other reurn lines. If your pool has more than one return line, check to see if that line is shooting water across the top of the pool, if so, you may want to adjust the flow downward at on angle. The returning water may be stopping the hose and the unit from going to the shallow end.
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
SOURCE: Cleaner lacks power won't climb sides
Hey Walt, Check the hose swivels. Alot of the time the hose swivels leak water which defreases the flow to the cleaner. Also, depening on the model Letro cleaner you have, it could be the gear teeth in the wheels. epoolshop.com
SOURCE: pentair legend 4 wheel cleaner - runs over its hose
check the white float on the cleaner. take it off and shake it, if it is full of water you will need to replace it. when they get water in them they make the cleaner heavy and it will tip of on its side.
SOURCE: My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
