Question about Crosley CDE6000 Electric Dryer
My dryer is taking too many times to dry my clothes!
I have a Crosley Electric dryer and it is drying the clothes but taking 2 runs to do so... I have taken it apart and cleaned any and all lint I could out of it... what else could be the problem and how could I check and fix it?
  • 706 Answers
Hello tmivie,
When you say you took the dryer apart and cleaned out all the lint, did you also check the vent system all the way to the outside and at the end where the duct exits your house? If you are getting heat and limited or restrictive air flow, your drying time will be excessive.. There may be other problems such as the blower itself isn't functioning properly to move the air out.. Since your dryer is electric, you can detach the vent line from the dryed and turn it on.. feel the exhaust flow to make sure it is pretty robust then reattach the vent and check for about the same flow at the exit point of your duct system. Let me know if that solves your problem or not so we can look at other ideas..
Regards,
Rick
Posted on Dec 01, 2008
Why would my crosley dryer get really hot but the clothes don't get dry
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
Jul 08, 2014 | Crosley CDE6000 Electric Dryer
Our Crosley CDE6000 electric dryer would shut off midway through a timed cycle w/ clothes not dried. I removed the door and front , then cleaned out a fairly good amount of lint from trap in door. Rep
sounds like your stat (Tod) for short has gone a Tod is what tell the dryer to heat and when to turn off you will have to replace them OK they are right on top of the heater OK hope this have helped
Oct 22, 2012 | Crosley CDE6000 Electric Dryer
Crosley cde22bgv, gets warm but won't blow right. Takes about 4 hours to dry a load of clothes.
check make sure the vent is not stopped up and that the blower wheel is not lose
Oct 03, 2010 | Crosley CDE6000 Electric Dryer
The dryer takes too long to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Crosley CDE6000 Electric Dryer
Sensor dry takes a couple of times to dry clothes
My mother has one of these machines. Less than a year old. I think that is just the nature of these dryers. The vent goes right through the wall and is a 2 foot run. I know their are no restrictions of any sort and the lint filter cleaned after every load. I have found that if I put it on More dry it does fairly well.
Apr 17, 2010 | Roper REX4634KQ Electric Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Have duet electric dryer model #9200Lw1 dries slowly
are you overloading the dryer, too many clothes would take longer to dry
Feb 03, 2018 | Whirlpool Dryers
Clothes take a very long time to dry
You need to remove the front panel and clean out the lint and replace that bad blower wheelaa0396a.jpg
Feb 21, 2009 | Crosley CDE6000 Electric Dryer
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Crosley CDE6000 Electric Dryer Logo
81 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
