Question about EverFocus EDSR1600/500
Problem recording Hello I have an Everfocus EDSR1600 and I can not get it to record. I have pressed the record button. . . . and nothing. Please help Nim
    Sniper:
  • 50 Answers
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked.
Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF.
Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU.
To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives.
The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Posted on Dec 03, 2008
Cannot remember password need to rest it on ECOR264-4D2
On some DVR's you can reset the password by downloading .bin files from the manufactures website onto a thumb drive. I've done it for other models just not Everfocus. It's pretty simple if you can get access to those files. After you have them on the thumb drive you power down the device, plug in the thumb drive, the device scans the thumb drive and resets your password back to default, hope that helps!
Dec 21, 2013 | EverFocus ECOR264-D2 ECOR264-8D2 8 Channel...
Connecting to pc
i fixed the problem.
please don't send me anymore emails.
thanks
Jan 06, 2010 | EverFocus EDSR1600 16 CHANNEL 160GB...
How do I copy something from the hard drive onto a DVD?
WELL , check out this DVD Recorder from SONY , CLICK ON THIS LINK:
http://reviews.cnet.com/dvd-drives/sony-dvdirect-mc5-multi/4505-3212_7-32565017.html , I THINK you can get a good price by going to EBAY , hope this helps , please rate thanks AJ
May 20, 2009 | EverFocus EDSR1600/500
EverFocus EDSR1600/500: system loading message stays
More than likely the small fan inside has burned out. Now both of your hard drives are fried. So replace the little fan. And install one working hard drive. Ive had to do this a few times. Ask a computor friend to help you instead of sending it in.good luck
Jan 30, 2009 | EverFocus EDSR1600/500
Edsr1600: clicking noise eminating from front right
I had the same problem. Left the unit on overnight, next morning the unit was working fine. Also if you turn the unit off and back on it can take up to a hour for the system to reboot.
Jan 02, 2009 | EverFocus EDSR1600 16 CHANNEL 160GB...
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
Camara
how get backup of HDD dvr EDSR1600?
Oct 29, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Recording
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Televison & Video Logo
338 people viewed this question
Top EverFocus Televison & Video Experts
Marvin
Marvin
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
