Question about HP Officejet 7210 All-In-One InkJet Printer
I have a Brother InteliFax 4100e. I'm trying to send a fax to a number that is long distance. First I was getting a communication error when I tried to send it. Now I am getting a Busy/No response message. Any ideas about how I can fix this?
  • 628 Answers
Does it work all right for other numbers besides the one you mentioned? Sometimes the problem is at the other end. They might have a noisy phone line. Try sending the fax to another place and check the result.
Posted on Dec 01, 2008
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
My brother intellifax 4100e is not recieving faxes we can send and I called the fax it works and we can copy but cant recieve.
Does the machine actually answer the incoming call? If so does it give an error code? Are you using the genuine brother line lead? Finally make sure the line lead is plugged into the "line" socket and not the "tel" socket.
Aug 15, 2011 | Brother IntelliFax-4100e Fax
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Fax won't transmit long distance faxes
Your long distance access is being blocked by the telephone company for some reason.
Apr 07, 2010 | Brother MFC-7220 Plain Paper Laser Fax
LED Message on Brother Intelifax 4100e says replace drum; drum has been replaced, but message is still showing
follow the instructions below:
  1. Open the front cover.
  2. Press the Clear key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Sep 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Inteifax 775 will not send fax
change the mode from TAD to F/T by pressing mode button on panel
Thanks
May 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Intelifax 1820c problem
that is a printhead error. call brother and see if its under warranty by giving them the serial number. if its not, the last i knew, the printhead w/ cartridges was about $100.00. hth, ray
May 31, 2007 | Brother IntelliFax-2820 Laser Fax
HP Officejet 7210 All-In-One InkJet Printer Logo
Ben Johnson
