Question about Coby TFDVD5000 Portable DVD Player
DVD starts to load but does not play.
When a DVD is inserted into the player it starts to load but then displays the message 'wrong regional disc'. However, we do have one DVD that does play (Cartoon Network). Have we adjusted the settings in some way? And how can we get it back?
  • 6 more comments
  • Syranox Nov 05, 2007
    I put in a burnt CD and tried to play it and it said wrong disk and this was after watching anther burnt CD. So I put in a Normal CD and tried to run it and it did the same thing said "Wrong disk"
  • Spartan117 Dec 11, 2007
    my tfdvd5000 with a screen is inserted and then it says wrong disc and then i tried six other dvds but it wouldnt work. do i need a cleaner for it or is it some other problem?
  • Peter Shaw Dec 18, 2007
    I couldn't get a response from Coby either. They did not respond to my e-mail. I suggest we all by a better player with more reliable after sales service.
  • Anonymous Dec 27, 2007
    yeah my wouldnt play either
  • Anonymous Feb 22, 2008
    I watched an entire dvd on my TF-DVD5000. I went to reinsert it an hour later and it keeps giving me the message "wrong disc". What happened in the one hour? Which setting could have changed? I haven't been able to find any trouble-shooting solutions.
  • GLorenz2 Jul 04, 2008
    I have a Coby DVD player and i put in any disc I wont and it says no disc.
  • nathan_ghel Dec 04, 2008
    my player wont play dvd.when i insert a disc reply no disc
  • jlisabradley Dec 22, 2008
    Coby VZON Portable DVD Player with Screen - When a DVD is put in, the screen keeps reading loading disc for a very long time and eventually reads wrong disc.
Not sure if anyone found this solution, worked for me.
1. Press SETUP
2. Press FFW, F REW, NEXT, PREVIOUS
3. Change the code to 255 using the RIGHT arrow key
This will unlock the DVD player for all regions.
Posted on Nov 13, 2008
I have a Coby DVD7107 with the same "Wrong Disk" problem. I emailed Coby a couple of days ago but now I know to not expect a response. I did find the cause of the problem, I first though it was the laser pickup, but when I defeated the door open switch I could see that when the unit did not load the DVD was only spinning at approximatly 1/3 or less of its normal speed. When the disk would spin at the high speed ( not very often) the DVD would load. So the problem seems to be either the driver motor that spins the dvd or the electronics that control the motor speed. Either way I guess we are all "screwed" when it comes to any assistance from Coby. I went to eBay to try and find the same model for parts or repair but all of them had the same problem listed - would not load - wrong disk. But we do have a nice monitor that you could hook up to an external DVD player (just make sure it isn't a Coby).
Posted on Jul 21, 2008
I have a coby TF DVD 5000 buyed a year at least.
suddenly it was out of service.
Three technicians said it a problem chip and anyone of them doesn´t have this piece. i tried to call COBY , but anybody answered me
Posted on Dec 16, 2007
Portable GPX 931B dvd player, comes on, load disc, then displays wrong region, will not play the dvd.
Does this happen with every DVD you try to play?DVD's are often manufactured for different regions around the world.
Oct 30, 2013 | GPX Pd931b 9" Portable Dvd Player
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
I insert a disc. It loads, then either 1 or 2 shows in the display, but nothing functions and the disc will not play. It is a region 2 disc I tried
\usually when a disc won`t play ,it just displays "No Disc".
Is the disc matching the dvd code?
Is the region code correct?
Have you checked what discs the dvd will play, in front of manual.
If those are ok the dvd must have condensation in it.
Place in a warm room,turn on and leave for 2-3 hrs
Then try again fingers crossed for you.
Dec 03, 2009 | Toshiba SD-3800 DVD Player
Can i make it region free?
HELLO
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
HOPE THIS HELPS ENJOY (:-)
Oct 11, 2009 | Daewoo DVG-9100N
Region problem
HELLO!
TRY THIS!
Turn on the player
Make sure disc tray is Open.
Press 9 9 9 9 on the remote, do it slowly.
Press what region you then require.
Press 0 (zero) for multi-region/region free playback.
When you are trying to play back a disc other than the region the machine is set up for, you will get a Wrong Region message.
ENJOY! (:-)
Oct 04, 2009 | Philips DVD625 DVD Player
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Sampo
POWER ON
OPEN/CLOSE
Key in 3,3,0,8,8,0 on the remote for region-free
OPEN/CLOSE
POWER OFF
Oct 02, 2007 | Sampo DVE-612 DVD Player
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same. www.dvdenergy.com/index.htm
Aug 06, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Coby TFDVD5000 Portable DVD Player Logo
1,641 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
