Question about Keurig B70 Coffee Maker
Slow coffee stream and smaller brew size with B70
Keurig B70 11 months old.
Cleaned B70 in accordance with manual (white vinegar) end of October and it worked fine - Thanksgiving week lots of use - really slowed down and brewed small cups (1/2 to 2/3 of size selected).
Cleaned again (per manual except I used whole gallon of vinegar) and it seemed to work better flushing water through. But still too slow and small with K-Cup (Timothy's).
We always fill unit with water from refridgerator (has filter/charcoal cartridge etc for ice maker) and we do not have especially hard water.
I do not hear or see an air pressure blow out at end of cycle (although that was evident when flushing water at the end of a cleaning proceedure).
Does this sound like a scaling problem, or could it be a weak pump??
  • 2 more comments
  • Anonymous Jan 22, 2009
    Our keurig B70 is no longer pushing the water through the k-cup. Without the cup, the hot water comes out just fine.
  • rexwinn Apr 05, 2009
    I have the same problem.
  • Anonymous Mar 15, 2014
    keeps shutting off between brewing cups of coffee. more often than prior times. have cleaned often but seems to have a smaller stream very soon after cleaning.
  • Anonymous Mar 25, 2014
    kept clean with vinegar had about one year and now not brewing although it says it is
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
Posted on Mar 14, 2009
This solution worked really well. Coffe maker works like new. One issue now, however: The little red rubber/foam disc that surrounded the top piercing needle came off, and won't stick back on. Any ideas for how to adhere that back on?
Posted on Aug 07, 2009
I followed rkopko's instructions and my unit now works better than ever too! Thanks rkopko!
Posted on May 01, 2009
Ok to run bleach through a keurig?
Check to see what your manual recommends and act accordingly.
Aug 19, 2017 | Washing Machines
In what month and year is Mad Men set?
Season 1 opens in March 1960 and finishes Thanksgiving Day, 24th November 1960. Season 2 picks up on Valentine's Day, 14th February 1962 and ends in October 1962 with the peaceful resolution of the Cuban missile crisis. Season 3 starts somewhere during Spring 1963 with Betty Draper (January Jones) being approximately six months pregnant and ends on the evening of 16th December 1963. Season 4 begins around Thanksgiving in November 1964 and ends in October 1965. Season 5 begins on Memorial Day weekend in May 1966 and ends in March 1967. Season 6 begins at Christmastime in December 1967 and ends on Thanksgiving Day, 28th November 1968. Season 7 begins in January 1969, around the inauguration of President Richard Nixon and ends mid-season on the morning of 22nd July 1969, two days after the successful moon landing of Apollo 11.
Sep 04, 2016 | Mad Men (2007)
My keurig 2.0 will not brew. Everything works fine up until you press the brew button. It sounds like it is going to brew for about a half a second and then it just stops. A fee drops of wwater come o
If it is an older one it has probably limed up and needs cleaned with white vinegar. Run through it repeatedly until things come out clean & not cloudy.
Dec 12, 2014 | Keurig K350 2.0 Brewer
Keurig Vue V700 not filling cup
You are experiencing a clog of the upper tube. Not outside but inside the tube. Use a paperclip, open an end force it up the tube to clear the deposits and your in business. Remember to do a Full cleaning now and again with vinegar solution. Keep Filter changes at least every 4 to 6 weeks.
Jan 18, 2014 | Keurig Vue V700 Brewing System - 110774
Does not brew runs but no coffee . Always used bottled water, cleaned with vinegar 3months ago. While trying to brew one of the cup size symbols stays lit ( not the size we have it set at)s
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 03, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B70 Coffee Maker Logo
1,935 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
