SOURCE: wep/wpa
Hi, doesn't really matter which, what is important is what ever it is you choose, it should be the same/consistent all through out the wireless network/system. example, if you choose wep $ key is 12345 in your router/AP, then all you wifi clients should be using wep $ key of 12345. Choosing or not choosing what wireless security mode to use is not preventing you to log unto the internet, they are designed that you can securely communicate/acces the router/ap and if granted acces, the router/ap will then be your gateway, so first you must be connected/logged on to the router/ap before you can share its internet. Hope this be of some help/ pls post again how things turn up. Kind regards.
SOURCE: WEP key
allright , do not worry about it, if u r able to go online with any of ur wirted or w/ls computers, open a new browser page.. login http://192.168.1.1, username - no name(leave it blank), for passwd- admin, u would be in linksys setup page , click wireless tab, you would see ur n/w name and click wireless security, sub tab in the blue bar , u would see ur encryption key details ..
SOURCE: How do i change the WEP key or even view it?
To access the SpeedStream 2623 management interface:
1. Open your Web browser and enter the SpeedStream IP address http://192.168.254.254 in the browser Address box. The SpeedStream 2623 will automatically switch to port 88 for management access.
2. On the Login Screen, enter admin in the Password box; then click Login to display the Status screen of the management interface.
3. Under Simple Setup , go to Wireless Settings - take note of the SSID (this is the name of your wireless network). By default the SSID is "SpeedStream".
4. Still under Simple Setup , go to Wireless Encryption:
Option 1:
A. On the Simple Setup > Wireless Encryption screen, select Automatically.
B. Enter a password or password phrase.
C. Click Generate.
D. Take note of Key 1. This is the key that you will have to use on the Wii to connect wirelessly.
E. Save Settings and Continue.
Option 2:
1. On the Simple Setup | Wireless Encryption screen, select Manually.
2. Enter a password or password phrase.
3. In the bottom half of the screen, select #1.
4. Enter five hexadecimal keys; e.g., a number or letter in the range of 0-9 or A-F.
5. Click Enter to save settings and continue.
You're done with the router. Go to the wireless settings of your Wii and configure it to connect to your wireless network. For a step by step instruction go to this site:
http://www.wiichat.com/nintendo-wii-online/5820-official-wii-wireless-internet-connection-guide.html
If you need further assistance, post a reply and I'll try to answer it ASAP.
Good luck and have a nice day!
SOURCE: Finding a Wep/Wpa Key
You need to open the router's admin page by opening your Internet Explorer. On the address bar type http://192.168.0.1 it will prompt you for username and password. By default the username is admin and the password is blank (no password). You can see the WEP or WPA key on the WIRELESS tab. Goodluck!
SOURCE: I just purchased a Netgear
WEP code will be 10 digits only...you need to type all the 10 digits together (without any spaces)... Try disabling netgear utility and use your default windows utility...It is not the problem with netgear....
