Question about IBM ThinkPad T23 Notebook
Black screen My Toshiba A75 S-206 laptop screen turn black . I can see the sreen data with a black veil, a dense black veil. I don't know if the cleaning I gave with an eyeglass cleaning liquid was the reason? Please help.
  • 1 more comment
  • liam toshiba Feb 26, 2009
    i goten my laptop a week or two ago mines a toshiba stellite A75-5229
    and whyen i accdently droped it, it showed a screen saying physical damage please shut down computer
    but when i turned it back on it wont work
    all it says is media files failure and keep saying the same thing over and over
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    This is what I found on it
    Toshiba A75-S206 Lcd Screen 15.4 Inch TruBrite WXGA TFT
    But again is sounds like another inverter board.....
  • Ismail Shifau May 11, 2010
    is your lcd a tft display?
  • 129 Answers
I think its the problem caused due to the cleaning. The TFT monitors are created by a array of minute display units which can be easily damaged if pressure is applied on them. Try connecting the screen to a different source to confirm its not a problem with the system. Once confirmed that the screen is damaged, you may have to buy a new one as there is virtualy that can be done to repair it.
Posted on Feb 07, 2009
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 21, 2012 | Toshiba Computers & Internet
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
Hi, I have acer Travel mate 6292 and i have recently changed the damaged LCD with a new one. But unfortunately i am still having a problem with it. i can hardly see the icons, screen is almost black. i...
recheck all the connections again to make sure they are all hooked up properly. especially any ribbon cables. you may have to take it apart again to ensure all the connections are what they should be inside the sreen.
May 22, 2011 | Acer TravelMate 2300 Notebook
MY FRIEND HAS A TOSHIBA LAPTOP.SHE DID SYSTEM RESTORE 3 TIMES(SHE PANICKED).NOW THE COMPUTER SAYS FILES MAY BE CORRUPTED.IT TRIES SYTEM REPAIR.WHEN ITS DONE SCREEN GOES BLACK.IF YOU TRY TO START NORMAL IT...
I was never put my file data at system disk. It's mean I always have two partition drive on my computer. So when the system crashes and can't repair, I can free to re-install the system without affecting my data. Base on my experience there is nothing to do than re-install your system. Backup your data first if its placed on system disk with Live operating system that you can found on internet such as SLAX Linux.
Jan 13, 2011 | Toshiba Computers & Internet
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
IBM ThinkPad T23 Notebook Logo
130 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
