Question about Plantronics - Bluetooth Headset Plus Base & Headset
Need a user manual for the Plantronics CS70 NC
I have received the Plantronics CS70 NC, however, there was no user manual. How can I obtain such a manual?
  • ken_springst Dec 02, 2008
    No solution yet - I thought like many other vendors there would be a manual available on the web site - negatory!
Http://www.plantronics.com/media/media_resources/literature/user_guides/cs70_ug_en.pdf
Just copy and paste that link above in a browser and get a 22 page official manual from Plantronics.
:O)
Posted on Jun 15, 2009
Mistake sorry everyone, plantronics voyager pro x cs70 .cannot get to work on my nokia c2-01 please help
Oftentimes there may be interference from other bluetooth devices on the phone. Disable them first, disconnect the battery from the phone for 30 seconds (helps to reset) and follow the pairing instructions from the link below.
Plantronics Voyager Pro User's Guide
Good luck from Headsets Direct!
Sep 30, 2011 | Plantronics CS70 Wireless Headset
No sound when coming from the headset
Check the compatibility setting on the left side of the Plantronics CS70 base, number "1" should be in the 3 O'clock position. Also check the cable connections, unplug and re-plug the cables. If the headset is dead, then the internal battery may be worn out and it may need to be replaced. The headset replacement model is 72910-01. Below is a link for the user guide to help with the compatibility settings and adjustments, as well as a link to the newer Plantronics headset that replaced the CS70.
Plantronics CS70 User's Guide
Plantronics Replacement Model 72910-01
Aug 26, 2011 | Plantronics CS70 Wireless Headset
OmI have a CS70 NC and I cannot walk very far and hear who I'm talking too. Also, the people/person I'm on a conference call with - I can't hear them very well. help please
My guess would be the battery is dying in your headset. The battery is not replaceable but the headset is. See link below.
http://www.headsetsdirect.com/72910-01-cs70n-headset.html
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics CS70 Wireless Headset
The headset picks up but it doesnt answer the phone. CS70 NC headset.
If it's not answering the phone, your phone may need to be programmed for auto-pick up so that it automatically opens the telephone line when you turn on your headset. Also, make sure the round compatibility dial (located to the left of the base) is set right (not between numbers and most phones work on setting #1).
Aug 09, 2011 | Plantronics CS70 Wireless Headset
Headset picks up but there's no dial tone and we can't dial out.
The CS70 headset is definitely paired up to the base and has a good connection if the lifter raises up, sounds like maybe the compatibility setting may need adjusting. The number one should be in the three O'clock position, the compatibility setting is on the left side of the base unit. Here is a link below for the user guide if you need help with the adjustment.
Jul 05, 2011 | Plantronics CS70 Wireless Headset
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Jun 10, 2011 | Plantronics CS70 Wireless Headset
How do I replace the mic tube?
The CS70 Voice Tube should pull straight out. To see a picture, click on the following link, scroll down to "Additional Information", click on "CS70 Wireless Headset User Guide" and scroll to page 18:
You can also find the replacement tubes by clicking below:
Plantronics CS70 Replacement Voice Tubes #72907-01
Good Luck from Headsets Direct!
Apr 14, 2011 | Plantronics CS70 Wireless Headset
Morning, my headset will put call on hold then i have to hit the "headset" button again on my phone to bring caller back
The CS70 headset only has the ability to mute a call. If you're phone is being put on hold when using the unit, you need to check and see how everything is configured. The user guide below will help you make sure everything is connected correctly.
Mar 28, 2011 | Plantronics CS70 Wireless Headset
Plantronics cs70 nc stop working
Make sure that the power is connected to the headset.  You can tell it's connected because there will be a red solid light on the left side of the front of the charging base.  Check the power cord for any frays and make sure it's plugged into the wall.  If it is, then try the following:
A system reset:
1.  Lift the headset off of the base. 2.  Make sure the headset is turned off.  The green light will not be on on the base. 3.  Hold down the minus button at the same time as the call answer button on the headset.  Hold them down for at least 10 seconds.  An orange light on the headset will flash several times.  It should go off when you let go of the buttons.  If the orange light stays solid, push the minus button once. 4.  Put the headset back in the charging cradle.  Leave it for 30 seconds.  Lift it back out of the cradle and try using it again.
Oct 01, 2008 | Plantronics CS70 Wireless Headset
Plantronics - Bluetooth Headset Plus Base & Headset Logo
7,369 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
