Question about Hotpoint Ovens
Replacement fan element fails to heat up.
A new manufacturers fan element has been fitted but it will not heat up,  all other elements work, fan runs,top oven ok, thermostat works. could another component in the element supply circuit be damaged, if so what is?.
    President:
  • 1,462 Answers
Two thoughts
is the thermostat open circuit?
there is sometimes an overheat stat adjacent to the element behind the outer casing. this can go open circuit
Posted on Dec 01, 2008
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
My belling fan oven does not give any heat fan is ok but no heat
If fan is working o/k, then it is going to be the element that is faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 08, 2010 | Belling Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
The fan at back of oven is working but no heat
Most likely the heating element has failed. You need to get it replaced, it is not a difficult job. Remove the old element and fit the new one.
Remember to switch of the power before starting work.
Dec 21, 2009 | Ovens
The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
Take my advice and fit a new element.
Thankyou.
Dec 03, 2009 | Baumatic Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Ovens Logo
135 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
