Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon Powershot SD500--LCD--No image in all modes. White Screen
LCD screen has no image. Only white screen with a couple colored streaks. This is case in all modes. Battery and Chip ok. Able to retrieve previously taken pictures. Not dropped or cracked. Thanks, Hap
  • hapwood2003 Dec 03, 2008
    When powered on I cannot access menu or any other function. The LCD screen remains the same--white with purple streaks. CCD sensor or LCD problem? If LCD can I fix?
    Sergeant:
  • 237 Answers
Hit the DISP button to turn display on.
If trying to show XXX image, this will become a problem
Make sure you are pointing the camera at something you want to look at versus a white wall.
If all these fails, the camera needs to be serviced.
Posted on Dec 03, 2008
  • Canon Master
  • 19,396 Answers
When you get colored bands on the LCD display, that means that you have either a faulty ribbon cable, or a faulty LCD panel.
  • Ginko
    Ginko Dec 03, 2008
    When you get no picture on display, and only white screen, or vertical bands , but the camera is working, saving files on the memory card and taking pictures, that means that either the LCD cable/connector, or the dissplay panel may have a problem.
    If the problem is the ribbon cable, this may be simply misplaced or defective.
    If the problem is the display , then it is faulty and must be replaced.
    If you do not know what the problem is you can replace both, the parts are not expensive.
    To replace the cable, or the display, both covers (fron t and back) must be removed, if this job is not being done by a qualified technician , there is a good chance to damage the camera in a bad way.
    If you want to senrd the camera for repair you can use the phone number listed on the owner manual.
    If you want to do it yourself you find disassembly instructions here :
    Powershot SD500
    another: Powershot SD500
  • Ginko
    Ginko Dec 03, 2008
    To know if it is a CCD sensor or LCD problem, you take some pictures, if pictures are being saved on memory card, then the CCD is ok.
    When is the CCD sensor, you get saved on the memory card the same picture with lines that you see on display, when you have LCD problems the camera often works fine, or does not work at all (if there is short on ribbon cable), but you never get a picture with the weird lines that you see on display.
    If camera does not take pictures, and does not work at all , it is not necessarily an LCD fault, but LCD faults are the most common cause for the problem you are describing.
My Canon PowerShot A460 cam is working well until yesterday, the biggest festival here in our place took place. teh flash, the lcd screen, etc is working... but, when i took pictures, the lcd screen turns...
Please try and reset the mode of the image to see if the LCD does not go blank when shown to higher light. Also if there is no issue with the indoor pictures then it is possible that the auto light detection is giving a higher value to reset the image balancing. Shift from Auto to manual mode and try.
Mar 18, 2011 | Canon PowerShot A460 Digital Camera
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis jvdzelde@bigpond.com
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Power problem with Canon Powershot SD500
Somehow you have damaged the internal LCD display, or, less likely, a portion of the optics have cracked. In the case of the PowerShot SD500 it will not be worth replacing either unless the camera is still under warranty. Standard warranty is one year.
May 05, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Picture pink tinted and with streaks
It is known problem of ccd imager chip failure in canon A95 camera. CCD imager chip will be replaced to fix this issue.
Canon offers free of cost repair of ccd imager problem in A95.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 19, 2009 | Canon PowerShot A95 Digital Camera
No image preview
You would need to buy a new lcd for this would be the obvious soltuon in this case. Do not shoot the messanger!
May 25, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
My Canon Powershot SD630
Dear Peter,
It sounds to me as though your camera is experiencing the early stages of a CCD sensor problem. Users will often experience color changes and/or lines in their LCD screens when viewed in picture taking modes at this stage of the problem. Later on their sensors will ultimately fail completely and they will typicallt get nothing but a black screen.
To differentiate between a sensor problem and a LCD screen problem, try viewing your LCD screen in several different shooting modes (e.g. automatic, manual, program AE, etc) and then view your screen while in your menu (by depressing the menu button in any shooting mode). If you can clearly see your menu (OR, while in playback, pictures that were taken before the issue began) then it is your CCD image sensor and not your LCD screen.
If, however, all of these modes gives you the same distortion, it is your LCD screen itself that has experienced a problem. In either case, however, the primary solution is to send the camera in for service.
If you are under your 1 Year warranty this is usually no problem. If you are out of your warranty period and (and this is a BIG and) are capable of repairing your digital camera yourself, you have the alternate option of ordering just the defective part and installing it yourself. Replacment parts, however, come with no technical support and no instructions so make absolutely sure you are capable of repairing the camera should you choose this lower cost repair option. Hope this helps.
Sincerely,
HeavyDLB
May 13, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Blank screen
did you press the disp. button?
May 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 21, 2008 | Canon PowerShot A75 Digital Camera
Photo screen problems
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Dec 09, 2007 | Canon PowerShot S1 IS Digital Camera
Canon powershot
Repair shop or replace - unless you are into taking stuff apart but in this case it is a major component failure I feel
May 30, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
