Question about Refrigerators
My Hotpoint refrigerator drips defrost water inside
I have found it necessary to keep a crock on the top shelf of the refrigerator to catch the water from the defrost. My guess is that some tube which would ordinarily carry this fluid down to a pan below the frig is blocked. Can I free this up myself, and if so, how should I go about it?
  • Charlie Jarman
    Charlie Jarman Dec 01, 2008
    Our brand isn't Hotpoint, but it does drip water inside -- when the fan for the freezer cycles off. We do not have an internal ice maker, although our fridge is capable of accepting one.
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
  • 8 Answers
SOURCE: ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Posted on Mar 06, 2009
Bat1956
  • 585 Answers
SOURCE: Water fills up the drip pan under the frig in
The water accumulation is the result of the defrosting process that occurs in every frost-free refrigerator and is directly proportional to the humidity and the amount of time the door spends open. Aother factor is the door seals. If the doors do not seal correctly, outside air will infiltrate the compartments and also add to the accumulation. The door seal problems sometimes are just simply due to the fridge not sitting on a level surface thereby skewing the box out of square. If the seals are bad, they can be replaced. If the box is not sitting square, there are leveling adjusters on the bottom. The time that the door spends open is up to you.
One more thing, there is a condenser fan under the box that moves air under the box to cool the condenser coils. The air movement also speeds the evaporation of the water in the pan. If the fan is not running, it can contribute to this problem, but will also cause problems with the refirgerator keeping it's cool. It might be a good idea to check the fan.
Hope this answers your question
Posted on Jul 06, 2009
  • 59 Answers
SOURCE: leaks from under frig. I think it is the hose
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
Thanks for asking.
Posted on May 25, 2010
oldTech2332
  • 2341 Answers
SOURCE: Model ET18NKXDW06. Water dripping
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Gene
Posted on Aug 10, 2011
Testimonial: "good"
Water keeps drain into the refridgerator but it still freezes and still keeps food cold in the ice box I just replaced the filter about a month ago.I also have been keeping a towel in there to soak up the...
Take out the back panel inside your freezer and locate the drip line in there, it should be some where under the coils, check if its blocked up with ice, if it is you need to unclog it. there should also be a wire that runs into that drip line (it helps defrost that line) you might need to replace that wire.
Feb 20, 2013 | Kenmore 64802 Top Freezer Refrigerator
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Inside top of the refrigerator, top panel would freeze and then thaw out,dripping water on the shelfs and down into the vegtables trays
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Whirlpool Refrigerators
Water fills up in bottom
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.Check for both possibilities. The solution to the trouble lies in one of them.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 18, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Water coming out of the center top of the
Your defrost drain hose has become dislodged. This happens a lot when people pressure wash their fridges. Look very carefully for a clear frosted looking hose under the panel and reconnect it.
Mar 09, 2010 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Condensation dripping from top of refrigerator
Feb 25, 2009 | Whirlpool Refrigerators
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
227 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
