Question about Epson TM-T88III Printer
Reciept's printing with gibberish
We have several Epson T88's on our network and have been getting some gibberish on the top right hand side of one of the printers. Before the header it prints "eg" and "{A62875....}" then the reciept is printed but cut off short. The customer signature area is cut off and then ends up on the top of the next reciept. I've tried updating the drivers and also other printers of the same model are using the same drivers and working fine. I found that the firmware is a more updated version than the printer which is working (10.0 not working vs. 7.0 which is working fine). How can I change the firmware on this printer back to an earlier version? And if firmware is not the problem what would be causing this?
  • 2785 Answers
SOURCE: solution to epson stylus photo r300
congrats for solving the problem
and thanks for posting your findings
keep up the good work
Posted on May 30, 2008
SOURCE: Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
Posted on Aug 18, 2008
Urgh! Yep, me too.
Posted on Aug 19, 2008
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
Tm-T88X is not supported by the Windows Vista 64-bit OS
Posted on Aug 24, 2008
  • 221 Answers
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Posted on May 30, 2009
  • 2666 Answers
SOURCE: when printing on cd by epson stylus photo r320
I have the print CD software, if you email me at I'll be happy to send it to you.
Posted on Jul 05, 2010
0 characters
1 Points
Epson T88...won't ink....paper does come out, but blank.
This is a thermal printer so make sure you have thermal paper. Take your finger nail or the end of a pen and rub the paper. It should make a black mark from the heat you generate on it. Also make sure the treated side is up,
Dec 05, 2009 | Epson TM T88 Thermal Printer
Printer showing error and paper out lights even
Cancel all the pending print commands from printer buffer that will be there in the bottom right hand side with an icon of small printer. And right click on the printer properties by going in Control Panel->Printers check the printer icon and do the right click and check whether it is offline or online. It should be Online.Click on the properties and click on Roll Back Driver option. Or either uninstall or reinstall the drivers either by Driver CD or by online. Restart the computer and then try to take the print.
Nov 19, 2009 | Epson TM T88 Thermal Printer
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Printers & Copiers
Only prints symbols, epson tm88
Typicaly means you have an incorrect print driver.
1st check your connections
2nd reinstall driver / software
Here is a website of drivers for this printer.
Aug 18, 2009 | Epson TM T88 Thermal Printer
using vb how can i change font size an epson tm88 prints
May 22, 2009 | Epson TM-T88III Thermal Printer
Prints Gibberish, not the Text - Epson Stylus 460
This is usually due to a corrupted driver. To fix this uninstall the printer using the Windows uninstall software facility on the Control Panel (I am presuming it's a Windows system, if not use the uninstall facility of your OS). Reboot the computer then re-install the printer. If you need more help with the uninstall/re-install processes, report back.
Feb 01, 2009 | Epson Stylus Color 460 InkJet Printer
Prints gibberish
print a selftest:
turn printer off then hold down the feed button, turn printer on and release feed button whenever it prints something.
pls reply back with info on printout, such as baud rate, parity and other info specially interface, thanks
May 13, 2008 | Epson TM-T88III Thermal Printer
You can use windows 2000 drivers on Vista for this printer, according to this article:
Jan 14, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III Printer Logo
61 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
