Question about Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter
Commport locks usining 4520 and 4060 to control turnstile
I have three duplicate setups with each PC connecting an Adams 4520 connected directly to the onboard RS232, linking with the Adams 4060. The lockup occurs mainly at night (but sometimes during the day) and blocks all access to the port. Error recieved is program already accessing port. The only solution we have found is to reboot. It does not occur all the time and may not effect all three setups at the same time.
What Quotes from 2nd US President John Adams..."One lawyer makes a....."
I have come to the conclusion that one useless man is called a disgrace; that two are called a law firm; and that three or more become a Congress!
There's a problem: John Adams didn't say it.
It's a line from the 1969 Broadway musical comedy 1776!
The character John Adams in the play said it.
Jul 07, 2014 | Measuring Tools & Sensors
I just purchased a notebook that had only been used a month. When I try to connect to my network I get an error message that my pass key is not correct. I'm sure the answer is simple but I can't figure...
i think you need to get your husband to sign in and see if it still locks you out.
if it lets you in then you will know, how when and why it all went wrong lol.
Jun 20, 2014 | HP Pavilion Computers & Internet
Need connect turnstile Perey to system Win7
Contact them:
308 Bishop Ave.
Bridgeport, CT06610
Toll Free 877-TURNSTILE
Tel. 203-333-9400
Fax 203-333-9410
May 05, 2014 | Office Equipment & Supplies
Kpg-49d and error please check radio type
Hi Ad,
The best advice I can give is: join yahoo group specific to your radio Make/Model, there you will obtain all the info you require plus you can download manuals, diagrams and other goodies.
I hope this helps you.
Regards,
Peter
Jan 30, 2013 | Kenwood Kpg-49d Radio Software
Hdd locked cannot install windows
If your HDD has a password on it, that is stored in the HDD firmware and renders the HDD useless without it.
Jun 02, 2017 | Toshiba Portege Computers & Internet
I am getting this error when trying to duplicate my advertisments discs "burner mixed or firmware version mixed" and it is even nt getting into advanced setup.. wht shud i do ?
If you can not go into " Advance setup" then you can't update your writer firmware through controller. The only thing you can do is connect you writer to a PC, update writer one by one and put all back to tower.
If all your writers are same brand ( NEC ) , but different model, this solution won't take care you problem. In this case, two way you can do:
1, Find out what the model that you have most and buy that one from any seller, remember " Update F/W to same version.
2. Get a ACARD controller, ACARD controller can mix brand, model and firmware in one system.
Dec 31, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Is there a way to setup my wireless network without connecting a computer directly to one of the router Lan ports? I would like to locate my router and cable modem in the center of my house on the main...
it is a good idea to have your pc plugged into the router during setup. with a wireless connection, you may loose your connection during setup since many routers need to "reboot" after changes are made. after the initial setup, making minor changes via wifi are acceptable.
Dec 12, 2010 | NetGear WNR2000 Wireless Router
Hello i am usin a compaq v3000 laptop.. I couldnot able to connect the internet..i have tried all the options could you please help ..
first of all install eathernet in ur system, if u r using a cable of landline phone.go to compaq site,
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=1842076&taskId=135
free register in it, by ur valid mail and password, type ur laptop no RD153AV in serch box. after that select ur operating system, after it u will find ur all drivers.load all wireless, and LAN Drivers. and install it.then connect ur net, and open controll pannel-open internet option
then after it--click on connection-click on setup-next-choose ur connection -and finish it.
now open it again-click connection-there is a box is u see ur coonection then ok, if not the --click on add and add ur connection.
if u have many connection in that box then --click ur connection which u r using.
now there are three option below box-click on always my set my default connection.
click on apply, and ok
above process for windowz xp, u can try above for vista.
Dec 30, 2008 | HP Compaq Presario v3000z Notebook
TV problem
Bad solder connect inside tuner = un- solder tuner from
PC board and solder bad connect or replace tuner with new..
I.F. block next to tuner should be soldered,also.......T.
Dec 08, 2007 | Sony KV-13TR28 13" TV
Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter Logo
51 people viewed this question
Top Advantech Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
