I have MFC-5440 cn. I was oprinting out invoices and it 'just' quit after the last one printed out. It will copy. All wires are plugged in.
  • Anonymous Jan 04, 2009
    My Borther MFC-5440 CN malfunctioned, with a paper jam filled with black ink. Once cleared, it said it needed black ink, which was replaced. It continues to give that message, or to install the cartridge (already done). It won't print, even with new black cartridge.
2 Suggested Answers
mitpatterson
  • 74 Answers
SOURCE: replacement paper tray for Brother MFC 5440 cn?
If you go to brothers website you should be able to order a new one from them for about $10 USD plus S+H or so
Posted on Oct 19, 2008
etaf
  • 779 Answers
SOURCE: Brother MFC 5440 CN, Can the color be turned off?
You may be able to select black only from the driver properties
One of the options is to use grey scale
goto printers right click on the printer Properties you may find the option within those settings
NOTE however, each time you switch the printer on it may use the colour as it starts and calibrates
Heres a link to the user manual http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc5440cn_all&dlid=&flang=English&type2=-1
direct link to the manuals For basic information about the product. http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UkEngSoft_D.pdf Software User's Guidehttp://welcome.solutions.brother.com/BSC/public/files/dlf/doc000075/BH3FB_UkEngUsr_B.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 31, 2010
Good Morning, My printer is printing blank pages. I changed all the ink cartridges so they are full. What should I do? I have a Brother MFC 5440 CN. If you require any additonal information please feel...
try it in another pc if you don't have
re-install the driver if not fixed
re-install windows if not, the last try is use another usb original cable
best regardes
if you see that is helpful plz don't forget to vote me
Apr 01, 2011 | Office Equipment & Supplies
I had never had an issue with this MFC 5440 CN until now,It was working perfectly and since a couple of days ago it does no want to print. All ink levels are OK, there are no pieces of paper stuck...
Ivan, see if there are some paper clips or other similar objects stuck somewhere around the paper rollers. There are micro-switches around the rollers, you may want to take a brush and clean up any dust buildup that may be causing these micro-switches to trick the printer into thinking that there's a paper jam of some kind
Dec 21, 2010 | Brother MFC-5440 Printer
Mar 31, 2010 | Brother MFC-5440 Printer
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5440CN Low Ink problem
Maybe you can try reinstalling the driver or if the cartridge was bought from 3rd party, you might want to buy one directly from the manufacturer.
Good Luck.
Feb 02, 2009 | Brother MFC-5440 Printer
I can't scan on my Brother MFC 5440 CN
Hi, remove the softsware that came with the Brother, and then re-install as per the manufacturers instructions
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Replacement paper tray for Brother MFC 5440 cn?
Jul 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer keeps restarting itself all the time, and does not print at all
Try downloading the latest firmware. Ti might sort it out for you.
Jan 30, 2007 | Brother MFC-5440 Printer
16 people viewed this question
k24674
