Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag Performa Dishwasher draws water then stops
My Maytag Performa Dishwasher draws in water as normal, then stops. The wash cycle doesn't start. All it does is hum/beep after about 30 seconds/1 minute, and continuously repeats that. The lights start flashing after a few minutes of the continuous beeping. I can drain the water by hitting the off button without any problems. Does this mean that the heating coils aren't working?
Thanks for any help. Chris
    Top Expert:
  • Maytag Master
  • 80,637 Answers
More than likely you need to replace the washer control panel.
Posted on Jul 19, 2017
5 Suggested Answers
  • 3 Answers
SOURCE: Dishwasher will not complete a cycle
check the pump it could be stuck
Posted on Mar 02, 2008
SOURCE: We have a Maytag MDBH950AWS Dishwasher that won't start.
I have Miele incognito that when I shut the door it does not turn on? Not sure why it stopped working all the sudden
Posted on Dec 23, 2008
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
ginko
  • 19396 Answers
SOURCE: Maytag performa convertible model no PDC3600AWX Water
Hi.
After checking that there is pressure at faucet and after ensuring that the inlet hose is not kinked or clogged, next part to test is the inlet valve.
The inlet valve is the part directly connected to the inlet hose. The valve is tested reading Ohms at its terminals, and checking if it does open and close when it is energized. If when you read impedance at valve contacts using a multimeter the valve returns infinity (open), then valve solenoid is shot, and the valve must be replaced. If the valve shows continuity, it may still be mechanically faulty. If the valve is not open when energized, then it is faulty.
Here the valve: Inlet Water Valve
If the valve is OK, then the next part to check is the float switch.
The float switch can be tested by jumping it. Other test can be done removing the switch from circuit and reading Ohms to check if the switch is opening and closing the circuit when the arm with the float is operated. This last test will not reveal problems caused by the floater (eg. float getting stuck).
Here the switch: Float Switch
Other part that must be tested is the door switch. This part is tested jumping its contacts and running a cycle.
Here part:Door Switch
If water level device (float switch) , inlet valve, and door switch are OK, then problem is usually the electronic control. The electronic control is replaced only after testing the parts above and checking wiring (use OhmMeter). All the tests must be performed by trained personal.
To locate parts refer to the diagrams in the part distributor website below:
Here all parts and diagrams for your appliance.
You can also get parts and diagrams by entering the full model number in any of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
Regards.
Ginko.
Posted on Nov 05, 2010
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
My Maytag Performa Dishwasher is leaking when doing the dishes...
Sounds like your fill valve is stuck in the filling position...see if you you have water standing in it a couple hrs after a drain cycle. if it does then the valve needs to be replaced or you can take it apart carefully,(there is a sping that might fly out and get lost) and clean it. Mine had some small trash in it from the city water line.. The left side has an over flow hole is where your water is coming from..
Nov 12, 2009 | Maytag Performa PAV2200
My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Jun 05, 2008 | Maytag Performa PAV2200
Maytag machine not spinning
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
May 31, 2008 | Maytag Performa PAV2200
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
131 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
