Will go back to normal, when power is turned off and on again, will be normal for a few minutes and then turn red screen again
This model and some others had bad picture tubes that are no longer available---there is an option here.
If screen gets bright red, green, or blue set will shut down as it detects too much current being drawn.
Seen over 100 with this issue--what can be tried and usually will help is a physical adjustment inside the set.
No parts to replace and takes about 15 minutes to do.
I can tell you how if you want to know.
SOURCE: Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
SOURCE: Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is [email protected]
SOURCE: hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
SOURCE: Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
