Question about Dell Inspiron 1501 Notebook
Power Hi, My dell laptop was running low on battery power, the critical light was blinking, I plugged in the ac adapter but it wasn't recognized and continued draining the battery, and now it will not power up at all. Please help. Thanks, Mike
  • mtdtaz115 Dec 02, 2008
    I checked the adapter it seems fine. Now I have a laptop that might as well be a dining tray. The critical light was a battery warning, the ac adapter was plugged in but was not recognized.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    have u checked the power adapter?perhaps a connection is loose..
  • 33 Answers
Hi Mike..
This case mean ..there is loss of power from the Chagring adapter or the power socket ..
so check the adapter with another Dell just to check if its charging or not...
else the power socket which u plug the adapter ..and that's what i guss quz u said the critical light was blinking,,
best luck
Posted on Dec 01, 2008
No power battery flashes 4 orange
If it is orange or is blinking orange, the battery charge is low or expended. Remove the battery and re-install it. Plug in the AC adapter and connect it to an outlet. Turn on the computer.
When the battery status light blinks green and orange, the battery temperature is too hot for charging. Shut down the laptop, detach the AC adapter, and allow the laptop and battery to return to room temperature before attempting to charge the battery.
If the battery status light blinks orange rapidly, the battery itself may be defective.
Apr 08, 2012 | Dell Inspiron 5150 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
My Dell Latitude D160 won't respond at all. I have to constantly push the power on button to even get it to come on and when it does, the battery light is on red and I think it says low critical power...
I'm confused too... it sounds like the power adapter is not (electrically) connecting to the laptop or the adapter is not delivering proper voltage/amps to the laptop.
You shoud 1. make sure that the AC plug is properly in the AC socket, 2. that the AC cord is (mechanically) connected to the adapter, and 3. that the adapter is (mechanically) connected to the laptop.
I cannot tell you how many laptops I have seen where the (internal) power connector breaks as a result of (typically) mis-handling, dropping, etc. Try (gently) wiggling the adapter connector and look for the LED changing colors.
You could also test the voltage output of the adapter with a standard Volt meter...
Sep 13, 2011 | Dell Latitude D610 Notebook
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Dell c640 laptop when not power on when using ac
The battery has a dry cell causing this so replace the battery
Jun 20, 2010 | Dell Latitude C640 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
No power for laptop Inspiron 1501
try removing the battery and connect the adapter then switch you pc on ,if it works, then you have to change your battery, else you have a bigger problem and need professional, if you are ask for more help.
Dec 02, 2008 | Dell Inspiron 1501 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 1501 Notebook Logo
206 people viewed this question
Alun Cox
