Question about Kenmore 46462 Front Load Washer
Water drains underneath washer
The washer leaks water during the drain cycle under the washer.
the drain hose has been checked and it is ok. It happens more often when the washer has a medium or large load but this washer is high capacity.
the model of my washer is 110.46462500 according to the parts list.
  • Anonymous Jan 11, 2009
    water coming down under washer?
    Problem Solver:
  • 7 Answers
The load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Posted on Dec 27, 2008
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
Loud Bang at End of Spin Cycle; Leak Underneath Washer
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
Jan 21, 2013 | Maytag Washing Machines
My Frigidaire Gallery front load washer is leaking water from underneath. Ideas?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Sep 03, 2011 | Frigidaire GLTF1240A Front Load Washer
My Gallery series Front load washer was making a loud buzzing noise and was not spinning. when i took my soaking wet clothes out there was a puddle of water inside. I tried the drain cycle and a new wash...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.In this case you need to check the free running off the mottor manually, check the voltage on the motor,If absent the controller is a suspecct. check the capacitor of the motor. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
My GE WCSE4160B2WW top load washer is leaking.
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker
thanks.
Nov 05, 2008 | GE WWSE5240D Top Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Kenmore 46462 Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
