Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
WS 55315 Tv won't turn on-
Push power on- green light comes on tv clicks and then 1-2 seconds later turns off. No picture ,no sound, no power. Tried self diagnostic, results were - 2 flashes then pause then 2 flashes. Un pluged for 1 hrs then plugged back in, same results. First time TV has given and problems, According to what I've read, flash twice pause flas twice, means that a voltage problem exhists, Power supply- fuse ????. Is this true?--- If so does anyone know approximate cost of repair, need to make some type of decision between repair vendors... Please respond
  • Carrie305 Dec 24, 2008
    My tv is doing exactly the same. I'm calling around for repair quotes and the lowest I have so far is $200-$300 with a $50 service charge to come to my home. Is this a difficult thing to fix as a do-it-yourself project? If I had step by step instructions, I would think I could do it but how would I go about finding instructions?
    New Friend:
Thanks for your help can you send photos so I can see what to look for
Posted on Oct 10, 2016
SD Tech
  • 14553 Answers
SOURCE: My Mitsubishi ws-55511 does not turn on. I push
1.) 2-2 is short protection and usually means one of the two fuses that protect the convergence IC are bad.
2.) This model uses a Single convergence IC--A STK-393-110 THAT can be purchased for about 14 dollars plus shipping on ebay.
3.) If one of the fuses that protect it is blown the set detects no voltage present and shuts down instantly.
4.) I have photos of what the fuses that need to be checked look like; also there are several protect resistors around the chip that need to be looked at also--I have photos of them also.
5.) I also have step by step start to finish instructions for this repair for this model--It tells you how to do the repair and everything you will need to do it.
6.) If you want the photos and instructions give me a vote here and I will email them to you free.
7.) I do this here for free so if this has been helpful take a minute and give me a vote here.
REGARDS, SD TECH
Posted on Sep 13, 2009
Testimonial: "This was a great step by step answer to my problem. Thanks!"
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Posted on Jun 05, 2008
  • 927 Answers
SOURCE: Mitsubishi WS-55315 audio no picture
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Sep 19, 2008
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
654 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
