Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The front keys are locked and I don't have a remote. Help
I can't change channels, control the volume or anything using the controls on the television. I don't know how it got locked. How can I unlock them?
  • 505 Answers
In the customer menu you can unlock but you need the code to access. If you have the mits remote, hit QV and 9 simultaneously, or SQV and 9. This will get past the code to enter your own to fix. Turn the front panel lock off when you get in. Mits also has problems with switches (hardware) failing.
Posted on Dec 06, 2008
Can't program comcast remote to yamaha yas-101
The only thing i was able to do was to use this link and make the remote learn the functions by following the instructions on the Yamaha web site for the sound bar to AUX. YAS 101
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/
I then used the instructions below to volume lock the aux so that i did not have to switch back and forth from cable to aux to adjust volume and change channels
Setting Global Volume Lock
Global Volume Lock will force the volume and mute keys to be controlled by one device.
  1. Press and hold the "Setup" key until a device key blinks twice.
  2. Type in the code 993. A device key should blink twice.
  3. Press and release the device key for the device you want the volume locked to.
  4. You will get two blinks if the lock is successful.
Jul 03, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
May 20, 2010 | Sylvania LC320SS8 32 in. LCD Television
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Harmony 890 channels and volume wont work
Sometimes you need to go into the menu page for the device that doesn't work and you need to "learn" the keys to the new remote. "Learn" meaning pressing the buttons on your original remote with the Infrared part of the remote facing the Infrared part of the new remote. This will help the Harmony remote duplicate the signal to the device you want to operate.
Apr 09, 2008 | Logitech Harmony 880 LCD Remote Control
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
