Question about Veo Mobile Connect Webcam
Veo webcam does not work with skype
My webcam works properly with the Veo software. But when I want to use it with skype, it does not work. I have tcked "enable video" on skype. When, on skype, I go to tools , then options, I can see my veo camera in the list of connected items but when I click in webcam parameters under skype, I just receive a message saying that skype cannot find my webcam.
many thanks in advance for your help
Best Regards
Thierry
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
  • Veo Master
  • 10,322 Answers
1st You download Webcam Driver.
Veo webcam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Veo Camera Drivers for Windows XP Vista Windows 7
Posted on Feb 23, 2014
I am trying to use my Veo camera with Skype. I cannot get a picture. Is there any software update that I can download to make my camera work with Skype?
I have read that the Veo Camera uses a Video format that is incompatible with Skype. I have also found that some have had success using Splitcam to control your Veo camera, and then setting Skype to use Splitcam as the camera of choice.
  1. Download Splitcam from www.splitcamera.com
  2. Install it, run it, click on the Video button and select your webcam. Click on the on button. You will see your face.
  3. Now go to Skype>Tools>Options>Video Setting and select Splitcam as your webcam.
If this doesn't work, you will more than likely need to get a new camera that is compatible with Skype.
Jun 07, 2011 | Veo Advanced Connect Webcam
Veo video on skype
Do you have MSN messenger or any other instant messenger program starting when your computer starts up, if so thats probably your problem.
Use MSconfig (in run box) or a program like cc cleaner to check your startup folder
Jul 26, 2010 | Veo Advanced Connect Webcam
My Veo Webcam works correctly except on Skype. When I try to use it on Skype my picture is all red and yellow. Not a clear picture. I tried adjusting the resolution settings through Skype and that did...
check out Skype webcam help
https://support.skype.com/en/faq/FA1267/I-set-up-video-but-it-doesn-t-work-What-s-wrong;jsessionid=451F10CB24F4C887E359486876B1C9DC?frompage=category
Jan 14, 2010 | Veo Connect Webcam
My veo camera works, but it doesn't work when i use skype.
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
Select your webcam as the default.
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Dec 22, 2009 | Veo Stingray
I'M NOT ABLE TO USE MY WEB CAM IN SKYPE PROGRAM MY WEBCAM IS VEO 650VS26X
You can try this ........ www.manycam.com
download manycam v 2.4.44
install the software first
then plug in veo web cam and it should work
Oct 10, 2009 | Veo Connect Webcam
My Veo web cam will not work with skype. why not? can i download a patch or something?
Have you configured your webcam to skype ?
If you have problems when you use your webcam in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your mic as the default microphone.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your webcam as the default Webcam
  7. Click Save.
  8. Test webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
Aug 29, 2009 | Veo Stingray
Webcam won't work with Skype
Normal 0 Also send this to your family and friends so they have their computer setup properly.
Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
Apr 06, 2009 | Veo Mobile Connect Webcam
My veo web cam dont work on the skype chat
go to www.splitcamera.com
Install the program... then run the application..
click on file, video source, veo mobile/advanced web camera
(you should see yourself in the application window)
then open you skype
click on tools, options, video settings
choose splitcam capture, save
worked for me..
I found this answer on the skype forums
Hope it helps you
Oct 31, 2008 | Veo Advanced Connect Webcam
Veo webcam with Skype
Jess please contact me Regarding this issue.
rdmercer@cableone.net
May 31, 2008 | Veo Mobile Connect Webcam
Veo Mobile Connect Webcam Logo
313 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
