Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Plain paper is coming out with toner on it
When I go to copy a plain white piece of paper I get tonner reside behind the plain white piece of paper.
Need to replace drum.
Posted on Dec 03, 2008
Tonner ink removes from copy canon ir 3300
you means wipe paper toner will missing up ???
like this is you fixing assembly spoil need change it, try to open you machine door right hand side ,hten see got any pieces plastics are dropping down at iron plate bottom side.
tonner-ink-removes-from-copy-canon-ir-womrtxbrietddijx4pifv04m-2-0.jpg see this part should got something pieces drop down to bottom iron plate if them are spoiled..
May 22, 2016 | Canon Office Equipment & Supplies
Hp 6500A plus won't copy
Does it still print ok? To troubleshoot you should try to copy from the glass and through the automatic document feeder to make sure it is a problem with the scanner and not a piece of paper blocking the scanning path.
Feb 14, 2015 | HP "HEWCN557A - Officejet 6500A Plus...
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
When i copy o print a document, it comes out with tonner and black dust stains, how can i clean it? Ricoh Aficio MP 1600
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Feb 16, 2010 | Ricoh Aficio MP 1600 Black and White...
Replaced the power supply/controller pca on a ricoh 2210l. prints fine, but copies come out black. adjust shading procedure yields copy with vertical black stripes and sometimes a faint negative image of...
If the tonner has gone old please take it out and shake if for atleast 2 to 3 minutes before putting it back and takng printouts. The issue would resolve but its a temporariy fix as you would require to change the tonner .
Let us know if you need further clarification.
Thanks
Dec 30, 2009 | Ricoh FAX2210L Plain Paper Laser
Blank copy just plain white paper
toner, charge or dev not in position or of cause we could go for upside down original, my guess toner 75% Carona/charge roller 20%, 4% Dev unit outa position, 1% blank original.....hows that for 20 years summed up on white paper;)
Nov 04, 2009 | Canon NP 6050 Copier
PAPER JAM
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 19, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Plain paper is coming out with black lines on it
if the lines on the copies happen only when you use the doc feeder then you have something on the small slot glass if you put the document on the glass and make a copy if there is still a line it is probably the drum
Dec 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Oct 17, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
Computers & Internet Logo
131 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
