Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Plain paper is coming out with black lines on it
When I go to copy a plain piece of white paper I get black lines. I have cleaned the roller with the function shown in the book and I have cleaned the glass.
  • 168 Answers
If the lines on the copies happen only when you use the doc feeder then you have something on the small slot glass if you put the document on the glass and make a copy if there is still a line it is probably the drum
Posted on Dec 08, 2008
WHEN WE MAKE A COPY THERE IS A DEFINITE WHITE VERTICAL LINE
open tha adf and take the white roller out and clean the glass put the roller back and it sould be ok.
May 10, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
How does one clean a panafax uf-770 fax machine? the copies are coming out black and it comes off on your hands.
You probably have a piece of paper wrapped around the fuser roller. You will need to call a technician
Apr 13, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Copystar 1815 problem!
Are you getting black or white lines on your copies when you use the adf? When you lift the adf up and look at the copy board glass for any dirt, next look at the small piece of glass next to it. The white out is on that part or the copyboard glass. Clean it off and you should be good to go. You would get paper jams if the white out is on the rollers. If you want to clean them use a rag with very little WD-40 on it and lightly rub the white out off. Yes, I did say WD-40, it is not just for squicks... Good Luck
Jan 30, 2009 | Copystar CS-1815 Digital Copier 042DD512
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Samsung sf 330
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Feb 23, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
1040 HP Fax
Have a good day.
Good luck.
Mac
Feb 23, 2008 | HP 1040 Plain Paper Inkjet Fax
Computers & Internet Logo
290 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
