Faulty line stage sv2918 sansui tv
Hello guys. the line output transistor keeps on blowing q411.. i've replaced c401 and the set plays.. but the transistor is overheating.. ive noticed that the right hand side of the screen is pulling in slightly.. but really not major.. the set plays 4 about and hour.... please advise..
  • 4,234 Answers
Can you please post the make and model. That would help u sto provide you with more details.
Thanks,
Dan
Posted on Dec 01, 2008
What is the value of cap c415 on sansui tv sv2918
Make sure you use an identical capacitor!
Feb 22, 2017 | Sansui Televison & Video
No heater for tv model no.SV2918
Check the continuity of the CRT heater [pin 1~8]. If it is found open, no need to proceed. If it has continuity, check the AC voltage there when the LOT works. Should have about 6.2VAC. If not, check all the solder terminals and series resisotr. connected to this bus. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jun 10, 2016 | Sansui Televison & Video
Sansui sv2918 has no picture only audio nd blank tv
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 09, 2016 | Sansui Televison & Video
A sansui tv switches on and off by itself. What could the problem?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Desolder out the horizontal output transistor, and now power on the set. If the set now powers ON, replace the horizontal output transistor. It is faulty. [Collector to emitter or collector to base leak]
Jun 26, 2015 | Sansui Televison & Video
Why is my Sansui Sv2918 tv constantly blowing the line output transistor
Try using a higher voltage for the replacement cap. Usually factory uses exact voltage but that can not handle surges.
Nov 07, 2014 | Televison & Video
Sansui sv29276
Replace all the capacitors connected to the horizontal output section. Especially capacitors connected to the collector of the horizontal output transistor.
Oct 16, 2012 | Sansui Televison & Video
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
When powering up all i get is a red screen with black lines across. Sound is still there and can change channels and ocationaly after several attempts it will give a picture albeit rather green.
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
Oct 16, 2010 | Loewe Aconda ACO9303 30" TV
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Mar 24, 2010 | Televison & Video
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
