Question about Reddy Heater-30-55,000 BTU Variable
Heater fires starts to heat and goes out
Filled with fresh kero, heater fires runs for a short time goes out before end cone gets red (hot)
  • 61 Answers
The most likely cause is your thermocouple. Make sure it is in the flame when it is lit.
Make sure it is clean. (if not a little piece of fine steel wool will clean it).
If that does not do it change your thermocouple.
Posted on Dec 01, 2008
I have a Goodman GMS8 furnace. The unit will start up but then go off so we have no heat. The LED light is not blinking and the rod gets red but then it goes out. What could the problem be?
Does the furnace fire then go out? If it fires then goes out its most likely the the flame sensor. This will be a steel rod that is in the path of the flame when it fires usually opposite end of ignitor. Take this off and clean it with steel wool or very fine sand paper. Make sure to pick the right part, the part that glows red is your hot surface ignitor and should never be touched as the grease on our fingers will react with the silicade nitrade and cause failure.
Dec 13, 2010 | Goodman GMS90703BXA Heater
CAN I PUT DIESEL IN MY KERO REDDY HEATER 150,000 BTU HEATER AND WILL IT SMELL OR RUIN IT
since the combustion temp of diesel is different from KERO, expect the heater to shut down from overheating at times.
since it will probably heat up faster than on KERO.
Jan 31, 2010 | Reddy R60A Utility Heater
Is it okay to burn Premium Diesel instead of Kero? Also, will I have a stronger odor problem with the premium instead of kero?
yes its ok, just make sure the air pressure pump is dialed in right. With the right air pressure the heater will perform at its best and burn as clean as it can. Its the slotted set screw (plastic usually) on the back next to the air filter. Turn it in 1/4 turn at a time till the nose cone is almost all red or orange in color. This will give you the cleanest burn. Then adjust doors/windows for fresh air as needed. Hope this helps
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Miller home heater -runs but clicks off and on,off and on, during heating cycle .so far it keeps coming back on to get up to selected temp but this hickup during heating cycle, what problem does this...
If the burner comes on and then after a while the burner turns off for a short time, minute or less then starts again, you might have a problem with your fan motor or a very dirty air filter. I could be going off on high limit and then resetting and working that squence of operation. Also if your unit has been worked on recently, a larger then needed nozzel could have been installed and the unit fan can not cool the heat exchanger quick enough.
Dec 14, 2009 | Heating & Cooling
Dayton kero heater wont fire
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Jan 15, 2009 | Dayton Electric Heater
Dayton kero heater wont fire0
OHH I bet this is the same question I just posted to. So it is a forced air kerosene. The usual is like I said a blocked combustion air hole. It could also be something shorting out the spark ignition to ground when replaces inspect the wires and look for a week or loose ground in this case. Sorry about the confusion.
A Bad ignition proving circuit or something like (what we call here dirt dobbers) hornets nest could be letting the flame hit it and not allowing full flow through the heater. Mice are also notorious for making problems like wires chewed and nests in the wrong place. Given where it may have been stored.
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Nov 29, 2007 | Scheu (K50-FA) Heater
Reddy Heater-30-55,000 BTU Variable Logo
126 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
