Question about Yahoo Messenger
Run-time error 340?
Ok I have windows vista, I downloaded yahoo messenger 9.0, it stopped working. so I decided to check out this website. I tried running it as the administrator and I thought it worked but then a message popped up saying " Run-time error 340, Control array element 3 does not exist" that popped up from a Y! Pilot.
I have tried to uninstall Y Messenger, but it stops in the process. I then restart the computer and nothing has changed. i'm so confused.
SOURCE: Problems with yahoo messenger 9
uninstall yahoos great betta 9 then get 7.0 here http://www.oldversion.com/
Posted on Jan 18, 2009
SOURCE: yahoo messenger can't be started or uninstalled
I have This message when I wanted to open my yahoo messenger
Yahoo! messenger has stopped working
A problem caused the problem to stop working correctly. windows will close the program and notify you if a solution is available
but I didn't get any solution. what should I do?.
Posted on Feb 10, 2009
  • 79 Answers
SOURCE: cannot sign in yahoo messenger
It may have 2 problems and 2 solutions:-
Firstly, this error occurs when your connection preferences are notproperly set. I'm not talking about your Yahoo! ID and Password here,but you may need to adjust certain features depending on what networkyou're on. Let's says for example, if a firewall protects your network,it may block yahoo messenger when it tries to connect to the server.You need to change your connection settings, click the Messenger menuin yahoo messenger and select Connection Preferences. Select FirewallWith No Proxies. Select your Internet Connection type from thepull-down menu at the bottom and enter your Home Country if theseoptions aren’t grayed out. Click OK and login again using the newsettings.If this option doesn’t work, click Connection Preferences inYahoo! Messenger again and select No Network Detection. Try to loginagain using the new settings. In some instances, you may need toprovide yahoo messenger with the IP address of your firewall or proxyserver (you can get this information from your network administrator orfrom your Internet service provider). Click Messenger and selectConnection Preferences again. Select Use Proxies. Enable either theHTTP Proxy or the SOCKS Proxy as needed and provide the proper address.Click OK and login again using the new settings.
Secondly, if you are using IM9 there are sign in problems. This is whatyahoo has to say.Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issuesthat have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix thatproblem. Even if you were experiencing a different kind of sign-inissue, I recommend installing this latest version.
Hope it can be helpful!
If you satisfied with this information, please do support me...
Thank You!
Posted on Jun 07, 2009
  • 42 Answers
SOURCE: YAHOO MESSENGER OPENS BUT WHEN
try cleaning CORRUPTED REGISTRY keys created by ymessenger with reginout, this problem will be hopefully resolved: http://www.reginout.com
Posted on Oct 10, 2010
SOURCE: Yahoo messenger social-view plugin error FIX =
how do it fix the socialview errors
Posted on Feb 08, 2011
I have just installed the yahoo messenger, downloaded from yahoo website. Its YM 9. After installation as i'm clicking on shortcut to start messenger, each time following error...
Uninstall YM 9
Install Yahoo! Messenger 10 instead by this link:
http://rd.software.yahoo.com/msgr/10/msgr10us.exe
When prompted, save the .exe file to your desktop. Then double click the Yahoo! Messenger 10 file on your desktop to begin installation.
Please rate.
May 27, 2011 | Yahoo Messenger
Cannot download ym it shows check firewall setting
You can disable your firewall setting when its hard trying to download Yahoo Messenger.
How to do that? Try this:
1. On your windows, click Start.
2. Click Control Panel
3. Double click Windows Firewall
4.On the General tab, select OFF(not recommended) and click OK
That's it! Your firewall setting is disabled and you can download yahoo messenger without being stopped by a message error.
If you have successfully download Yahoo messenger by disabling windows firewall and still cannot sign-in, you will be needing some tips on how to solve connection issues for Yahoo Messenger. Check this helpful tips http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Please comeback and give me some ratings if this one help you.
Thank You for using Fixya!
Jun 06, 2010 | Yahoo Messenger
Why my yahoo messenge 8.0 always stop working? what version of messenger match to my windows vista home premium?
download the new version of yahoo messenger from http://messenger.yahoo.com/ and install it.it works fine with windows vista. gudluk!
Feb 19, 2010 | Yahoo Messenger
My yahoo messenger 9 hada problem of error in chating it just han
http://download.yimg.com/ycs/msg/dl/msgr9/us/ymsgr900_2162_us.exe
This will work with Vista too. use the link to download yahoo instant messenger version 9. You must first remove any previous installations using the Add/Remove Programs in Windows. then run this .exe file to start the install.
Jan 19, 2010 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
I cannot run yahoo messenger on my vista ultimate. It always stopped working.I cannot run yahoo messenger 9 on my vista ultimate. It always stopped working.
it might just not be compatible with vista..alot of things are like that i wold search on yahoo.com for a vista version
Oct 27, 2008 | Yahoo Messenger
make sure you update all to the latest drivers via windows update
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 20, 2008 | Yahoo Messenger
Yahoo messenger latest version(beta 9)
yahoo messenger beta 9 doesn't work in vista...
try another OS...
try Xp SP2.....
Sep 27, 2008 | Computers & Internet
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
