Question about Toshiba Satellite A65-S126 Notebook
Audio jack i coudl listen to my music i downloaded and when i plugged my headset in then it play well now i am not getting anything, i had to reinstall my audio card i wonder if that had something to do with it!
  • Toshiba Master
  • 6,487 Answers
If you can try to use a different headset it will be better sp we can check if this is a problem with the headset or with the audio device on your computer, and if you try a different headset and still no sound better if you can uninstall and reinstall the audio software from your computer and that hsoul fix the problem....
Posted on Dec 01, 2008
    President:
  • 2,110 Answers
Try to re install audio driver from toshiba web site...
Unable to listen music in Nokia BH 108
Hi! The Nokia BH 108 headset does not have the A2DP function (advanced audio distribution profile). However, if you are using NOKIA (symbian) non-windows phone, you can play music since the phone bypass the said restriction. You may want to try other bluetooth headsets that has A2DP function so you can enjoy the musics from your headset.
Thanks.
May 06, 2013 | Sony Xperia miro ST23i Smartphone -...
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
Hello, When I connect my headset on my laptop Asus a7sv I get sound but no sound from the speakers. I have Windows Vista en I downloaded the original driver from the asus website. I tried everything....
Most headphone jacks operate as you describe. There is a switch built into the jack that diverts the audio from the speakers to the headphones for "private listening". If it didn't work this way, there would be no way that you could enjoy an audio track or other program with others having to hearing it, too.
You could get around this problem by using an external speaker set and a "splitter cable".
A splitter cable is simply a three ended cable like the one pictured above. The first end has a male plug that matches the jack on your computer - likely a stereo mini plug. The other two ends are usually the same; but the female version. You would plug the splitter into the SPEAKER jack and the laptop speakers would be silenced. Next, you would plug the the external speakers into one of the splitter jacks and then your headset would plug into the remaining splitter jack. You would connect the microphone plug into the MIC jack on the laptop.
You'll have to tinker with the sound levels as there will be feedback issues - depending on how close and loud the speakers are to the headset microphone.
Please rate this reply - and good luck!
Aug 09, 2010 | Computers & Internet
How do I get the headset, set up so I can use it. I plug it into my computer and nothing happens. Do I have to download something first? There are no directions with it. And if I have to download it, how...
There is no need to dodownload something. assuming that you have already installed correctly the audio card drivers. If you are able to hear sounds from the speakers, the audio card is installed correctly. So plug the green male jack to the green female jack and the red male one at the red female jack (if your headset has no mic, is only headphones, there isn't any red jack). From now on you must be able to hear sounds from the headphones and talk to the mic for someone to listen.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | Microsoft LifeChat™ LX-3000 Headset
I have the headset with the jack hook up not usb and I would like to know how to get music to come through my computer speakers while I'm talking on my headset and hear the person I'm talking to through my...
You are using one sound device at a time, this is not possible, if you like to be able to hear from headset and play music on your pc at a time, you must have a USB Amplifier and Headset (eg: GN Netcom, Avaya, etc...)
first you must set your Media Player's Option to Devices>Speakers>Audio device to use> DirectSound of your PC.
The other one is your are using a program to talk to other people, that program also has a feature to select the Audio devices to use, you must select that other device like my example above.
Hope this is clear enough to help you out.
Oct 21, 2009 | Computers & Internet
My lg dare has no audio i cant hear or be heard, I cant even hear the dial tone, how can i fix it? I am having the same problem with my dare. I tried plugging in headphones but it didnt help. I can hear...
You probably plugged a headset that does not have a mic. after you unplug it your phone will think that the head set is still plugged in. these phones are stupid and after you unplug the headset it will still be looking for the mic. Plug in and out the headset rapidly and then your phone will give you a notice saying that there is no mic to the headset. this will fix your problem. P.S. keep insisting, this fixed my problem
May 28, 2009 | LG Dare VX9700 Cell Phone
Ipod 30G video audio output stopped working
There could be something going on with the contacts in the headset jack. If you can get the back of the Ipod off and plug a headset into it, check the two metal pieces on the jack to make sure that the black lines on the plug are in contact with the end of the headset. They can be realigned by simply bending them back into place.
Nov 15, 2008 | Apple iPod MA446LL/A MP3 Player
Toshiba Satellite A65-S126 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
