Question about Gigabyte GA-8I865GME-775 Motherboard
When i connect my cpu to monitor i cannot get the display
The power is coming into cpu . fan is running . dvd drive is also working.i canot get bios config also
  • 2 more comments
  • sandilya_ch Dec 01, 2008
    can i get the manual from internet if i can where can i???????
    i tried it but no use???????? can i have another solution
    GA-8I865GME-775 Motherboard GIGABYTE
    pls give a solution plssssssssss
  • Gigabyte Master
  • 4,806 Answers
Try reseating the memory, looks like this:when i connect my cpu to monitor i cannot get the  - 893eaf5.jpg
or clear the cmos
kind regards and please don't forget to rate
Posted on Dec 01, 2008
  • Lee Hodgson
    Lee Hodgson Dec 01, 2008
    we need the make and model number of the motherboard please
  • Gigabyte Master
  • 6,487 Answers
If you have the user manual for your computer's motherboard you can find there the way to reset BIOS confifguration and after that you should be able to access now the BIOS and do anything that you have to do....
  • Mark Gil
    Mark Gil Dec 01, 2008
    I was willing to help you with your problem but giving me a rating like that , there will be no expert to help you with that problem..
    If you like me to help youfurther with this problem just change the rating that you gave me...
  • Mark Gil
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
I have change my old CPU intel Celeron D 3.06Ghz to intel dual 2 core but my pc no display my pc is power on my monitor is power on also. The CPU fan is running slower then old CPU . My motherboard
is the monitor running through a vga connection? sounds to me like the mobo is bypassing the connection your using and sending your video signal elswhere. did you change any settings in the bios? try other video outputs to get the screen on then go into bios settings and change the video output to a connection your familiar with. help is here if you need it :)
Nov 20, 2012 | Computers & Internet
Machine wont boot
There is your answer no power to the monitor. Make sure it is plugged in replace with another monitor if you cannot get the button on the monitor to power on the unit. Maybe time for another monitor. John
Apr 20, 2012 | Dell XPS 210 PC Desktop
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
Problem:Monitor problem and Dvd drive problem
open your cpu and clean all dust from it.reattch all power connection and harddisk connection .also clean dust form RAM and refix it.
ten enter i bios setup.
then load optimal defaults settings.ten save and exit.
Feb 02, 2009 | HP Compaq Presario SR5612F-B Desktop PC &...
When i connect my cpu to monitor i cannot get the display on monitor . but i am getting power that is fan is running. bios is also not coming
take off the power cord, remove the memory cards clean the slots and the card with a brush and re plug it in. and see if that helps. if that doesnt help check with another memory card and see if the display comes. and if that doesnt help remove all the ide and sata drives and then try, u may also want to reset the cmos. and also that doesnt help u can check your motherboard with another processor if u can get it. and if that also doesnt help. it means there's something wrong with the motherboard.
Dec 01, 2008 | Gigabyte GA-8I865GME-775 Motherboard
No display, no start up beep, no post and no boot
You need a Molex power plug (same as for your standard IDE hard drive or DVD drive to an 8pin adapter. A common product. If you can't get it locally.
Without this the board won't boot as there is insuffcient power on the motherboard to drive your display adapter.
Here is the link to the product at crazypc.com.
Also, if you have onboard video too, make sure the bios setup pages have the property set for primary display adapter to Add-in/PCIe.
Regards,
Worldvet
Jun 19, 2008 | Intel Motherboard
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Jan 13, 2006 | HP (D9820-60007) Motherboard
Computers & Internet Logo
70 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
