Question about Mitel 5220 IP Phone
How do I reset the time on our Mitel 5220 IP Phone?
Switchboard phone with multi-lines and extensions
  • dumbyhead May 11, 2010
    What Mitel system do you have?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
What Mitel phone system do you have. 3300ICP you can change it in programming same with a 200ICP.
Posted on May 14, 2009
How can I change the direction of incoming calls to various extensions?
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Apr 10, 2015 | Panasonic KX-DT333-B Digital Phone
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
Do I need to dial 9 before entering the telephone number
If you are a home user, then no. If you are in an office that has a switchboard and the fax uses an extension from the switchboard then yes ( it may on some systems be a 1 or a 3 instead of 9).
If you are in an office and the fax has its own line then again no. Its easier to just an ordinary phone into the socket and see which way works.
Jun 29, 2014 | Canon Pixma MX452
How do I set the extensions for the nightbell function on the KX-DT343?
Ringing is controlled by an ICD group. You can do it from the control phone, but I wouldn't. Better to call your installer/dealer/service tech and have them do it. In programming from the console it's program 620 and 621 IIRC (that or 621 and 622)
Carl
Mar 13, 2013 | Panasonic KXDT343 Phone
Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Answering
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing.
Thank you.
Mar 25, 2010 | Panasonic KX-T7730 Corded Phone
Answering the phone
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number.
Thank you
Nov 19, 2009 | Panasonic KX-T7730 Corded Phone
Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Jan 15, 2009 | Panasonic KX-T7730 Corded Phone
M7208
Dear Sue Johnson
Right, well immediately you have given me a symptom of a fault with the LCD (Liquid Crystal Diode display), and my guess is that if the display is not liquid induced or that it is not broken, then the only thing left to rule rule out is power failure to that part of the circuitry. Now i would have tothoroughly investigate why this happened before i could pinpoint exactly what the fault is, but a good guess would be either bad refurbishment, or liquid induction/ ingression previously has damaged components.
Now about the extension problem, I wouldstart off by stating that the refurbed portion of the system may have malfunctioned again or even elsewhere on the device, which may or may not have been directly caused by refurbishing involvement.
Im guessing that either your switchboard controller is faulty, or possibly a fault somewhere in the switching equipment that is in direct relation to data transfer over the RJ45 connectors (standard phone/ network cable type connection)
Your best bet is to remove all of the phones on the extension/ switchboard and then install them one-by-one and see what errors are thrown up, the ones that cause you a problem and then tackle the switchboard with the direct fault.
If all of this is to do with the phone (s) and not the switchboard, then i would say, remove the phones, replace them with a similar type and then notify someone like myself who may be able to advice you on your next best course of action. But if yor phone network is that valuable, then i strongly suggest selling the broken phones for spares / repairs and using the money to at least cover part of the cost of purchasing new ones of the same make and model as the ones on the rest of your local system.
The same will obviously apply to the switchboard, unless there are user servicable components inside, or you are particularly handy with electronics, comms technology and a soldering iron.
In the mean time, I wish you all of the best luck, and I hope to hear more about this situation soon, I also look forward to helping you the best i can with regards to this matter.
Yours sincerely
oz
P.S.,
Im logged on here 24hrs 7/365 days year now, so if you need advice, then im only a click and a few questions/ comments away
Apr 10, 2008 | NorStar BCM-T7208 Corded Phone
Mitel 5220 IP Phone Logo
516 people viewed this question
Top Mitel Computers & Internet Experts
Marvin
Marvin
Gil Shultz
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
