Question about GE PDS22SIS Bottom Freezer Refrigerator
BLANK DISPLAY AND CLICKING SOUND
I HAVE A GE PROFILE FRIDGE WITH BOTTOM FREEZER. SOMETIMES THE DISPLAY WILL WORK MOSTLY IT WON'T. ALSO, IT WILL MAKE A CLICKING SOUND COMING FROM THE BACK WHERE THE COMPUTER BOARD IS. DO YOU HAVE ANY IDEAS WHAT IT MIGHT BE? THANK YOU
  • Phillip Hayes Dec 05, 2008
    Sometimes the LED display goes out completely and sometimes it works normally. Also there is a steady clicking (about once a second) that comes and goes. Every few days I hear the clicking, and it usually goes away in 20 minutes or so. The clicking is coming from the lower right of the frig compartment (at the rear wall).
  • Susan 1234 Feb 20, 2009
    That sounds exactly like what happened to me last week! (GE Profile PDS22SBSARSS.) Display worked intermittently, then clicking which usually stopped after 20-30 min. Eventually fridge clicked all night and both fridge/freezer stopped working at some point. No more cooling. Can I assume it is also the control board? Is this something I can fix myself? If so, how savvy do I have to be? - signed, handy single mom on a budget
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display fixed and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Posted on Dec 24, 2008
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Ge profile bottom mount and temperature control
sounds like the mother board maybe bad. we replace alot of those , or 2nd i would say a display board .
Sep 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
I HAVE A GE PROFILE FRIDGE, WITH BOTTOM FREEZER. THE DISPLAY WORKS SOMETIMES OTHER TIMES IT IS BLANK. ALSO EVERY NOW THEN I GET A CLICKING SOUND FROM THE COMPUTER BOARD IN THE BACK, SOMETIMES IT LAST FOR A...
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display works and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Dec 01, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Freezer Temp display sya -47 deg and won't change
Check with mfg for a hard reset of the electronics. There may be some sort of hidden code with which to accomplish this.
Sep 05, 2017 | Refrigerators
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE PDS22SIS Bottom Freezer Refrigerator Logo
387 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
