Question about HP ScanJet 2400 Flatbed Scanner
My entire system crashed, and i lost the scanner software. right now, i cannot scan documents.
  • 162 Answers
Get an updated software at hp's website
Posted on Dec 01, 2008
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
Try reinstalling the driver software. If the problem still persists, run scandisk or reinstall OS.
S. Mohan
Aug 21, 2008 | Canon DR-9080C Path-Through Scanner
Cannont scan to PDF or RTF with HP PSC 2410 All-In-One InkJet
You have a problem with your scanner software or your operating system.Try connecting you scanner to another computer, install the software, and try scanning.
Jun 27, 2008 | HP PSC 2410 All-In-One InkJet Printer
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Download the software of scan benq 4300 or the setting
pls help me i lost my scanner 4300 cd, and i need the soft to be able t o use it again
Oct 27, 2007 | BenQ Scan to Web 4300U Flatbed Scanner
HP ScanJet 2400 Flatbed Scanner Logo
18 people viewed this question
Seeker5211
Seeker5211
