Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch BF71 not working
My bosch BF71 seems to be stuck in the drain mode It was showing an F on the control panel, if I open the door it still runs although there is no water visible. It then leaked water out all over the kitchen floor.I have had an engineer out who got it running, he said it was a blockage. It is now doing the same thing again after only a couple days since it was fixed. Anyone got any ideas. There is aslo a strong smell about, bit like rotting cabbage which isn't pleaseant.
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Posted on Mar 09, 2008
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
howapp
SOURCE: My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
Posted on May 21, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch dishwasher stuck on drain cycle. Where would I find the float valve?
If the D/W tries to drain when the door is open, you will have water in the tray. open the service panel and check to see, drain, then run. Location on most Bosch D/W float is mounted on left chassis.
Sep 30, 2010 | Dishwashers
Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Jul 07, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
May 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
67 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
