Question about Lexmark X4530 InkJet Printer
Lexmark X4530m adding extra color lines when copying in color.
When making a copy of a color or black page using the black button option the copy is OK. However when the same page is copied using the color copy button it adds two or three colored lines about 1/8inch wide horizonally the full width of the page. These lines vary in color from gray to the full spectrum. It also appears that if it is a photo being copied then the line color in the photo is a shift in the colors in the photo toward the right.
I can hear the process halt just prior to the errant printing then speed up as it lays down the extra lines, prior to going back to the correct printing.
  • 116 Answers
SOURCE: White vertical lines in copy
I would put the old cartridge back in if you can and do a test scan, the cartdridge you put in may be at fault, the trick is to duplicate the problem and solution, if nothing else take the new cartridge back and get another.
Posted on Dec 11, 2008
dburns60
  • 410 Answers
SOURCE: Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Posted on Jun 30, 2009
  • 37 Answers
SOURCE: my lexmark doesnt print color copies
CTRL P
make sure that color printing is checked..
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: Lexmark 5075 - vertical line on copies or scans only
Clean all glass with 70% isopropal alcohol on the scanner. If the line is perfectly straight and crisp. There a spec on the glass probally causing the line.
Posted on Feb 21, 2010
  • 48 Answers
SOURCE: Put new black and color cartridges, will not print
Maybe the printer need to clean a slot for a catridge. Because that printer stuck with old tint in the head for a printer therefore it need clean the heads.
Posted on Nov 28, 2010
Can the lexmark x75 all in 1 printer be used with out being hooked up to a pc
hi ginger slipp, If the catridges are in place and when you open it the light is green the without connecting it to a pc it can be used only as black and color copier. just put the the page you want to copy in the scanner the press the color copy button or the black copy button to start copying!!!
Hope it helps!!!
Thanks and please click the green ACCEPT button if you are satisfied with my answer!
Jun 27, 2011 | Lexmark X75 All-In-One InkJet Printer
How we make photocopy in a x1190
You can photocopy on this printer by following these steps:
Note: You can make a quick color or black and white copy.
Press Color Copy or Black Copy on the control panel.
To make black and white, gray, or color copies:
1 Open the top cover of the All-In-One.
2 Place the item you want to copy face down on the glass. Make sure
the upper left corner of the front of the item aligns with the arrow.
3 Close the top cover.
4 Open the Lexmark All-In-One Center (see page 3).
The All-In-One Main Page displays.
5 Click See More Copy Settings to review and change the copy
settings.
6 Select your copy settings.
Note: You may want to reduce or enlarge the image.
7 Click Copy Now.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Lexmark X1190 All-In-One InkJet Printer
I want to test printer with no conection to the PC only test page. What buttons Can I press for to print test page directly of printer?
Hi, you can't print a test page directly from the printer, but since it's a copier also, you can copy a page of text or graphics to make sure everything prints okay. Just place a piece of paper on the glass and press either the black or color copy button. (The computer must be on to make a copy.)
Sep 26, 2010 | Lexmark P3150 All-In-One InkJet Printer
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
No booklet came with my lexmark 2600 series
For color copies, you press the function key with two pieces of paper and color dots on it. For black and white copies, you press the function key with two pieces of paper and black dots on it. The link below is to the user's guide for your printer. Page 17 shows a diagram of the function keys, also, page 39 provides steps for making copies.
Lexmark 2600 Series User's Guide
Jun 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Copies
Hey :), I'd be happy to help. To make a copy you must lift the lid and lay down the item you want copied. And then on the side of the printer you will see a line of buttons , to copy the item you want,you have to let the printer know if you want the copy to be in black and white or color .To let the printer know of you want the copy to be in black and white or color, you have to select/press between the black ( black and white ) button in the line of buttons or the color button. Once you press wither of these buttons/options , the printer will automatically start the coping process. thanks! I hope this helps :)
Oct 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
HP J5780 All in one printer
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Jun 05, 2008 | HP Officejet J5780 All-In-One InkJet...
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Silan
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X4530 InkJet Printer Logo
161 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
