Question about Matsunichi MF326 MP3 Player
Drive is not accessible. I/O Device Error
Drive is not accessible. The request cannot be performed because of an I/O Device Error When accessing the above said error occured
  • 3 more comments
  • mi6a May 05, 2008
    when i plug my zen mp3 player it says I/O device error
  • Anonymous May 26, 2008
    D\ ISNOT ACCESSIBLE. THE REQUEST COULD NOT BE PERFORMED BECAUSE OF AN I/O DEVICE ERROR
  • dimitris8390 May 30, 2008
    D:\ is not accessible.The request could not be performed because of an I\O device error.
    I did a format but the problem solved only for a while.
  • Anonymous Dec 01, 2008
    yes....................
  • Anonymous Dec 24, 2008
    Same problem ... can't play audio CDs, DVDs, nothing.
Posted on Oct 11, 2008
Iq device error
Posted on Jul 21, 2008
When i connect my ipod and i cant able to add songs ,delete songs in that say me some proper solution for that
Posted on Nov 22, 2009
Help me please
Posted on Nov 15, 2008
Detecting but unable to perform any action..
if you have a linux distribution at all (eg Ubuntu, Fedora) or download a linux distro and use a live version (which is smaller than full version and can be ran off a usb so switch your machine to boot to usb once distro is on there) then you should be able to see the hard drive on a linux distro all fine with all files still on there. Also another option is get a virtual box program and open linux from that and access your files in that virtual distro
Dec 01, 2013 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I/O device error
Hmm? Your drive may be corrupted which makes it unuseable. I hate to admit your files may be lost at this point also. In order to reuse the unit, repartion and format the unit. I hope this helps.
Jul 14, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
IO Device Error
My Maxtor died like this. The disk was OK, it was the electronics that blew. I bought a new empty disk drive box and fitted the disk drive and fixed it. Years later the disk still works in the replacement box and power supply. I got my files and data back with the disk drive in the new box. The size of that disk looks small today. It may be Parallel (PATA) and you need a PATA box, that is harder to find as obsolete. You need to try the disk first in another drive holder.
So PATA and SATA??? Look here and read up about it with pictures too:
https://askleo.com/whats_the_difference_between_sata_and_pata_and_ide/
An external disk unit has three main parts.
1. The disk drive.
2. The electronics box.
3. The power supply.
Sep 08, 2017 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Can not access device neither directly nor via PC
I have the same frigging problem with mine. What's the solution?
Mar 19, 2008 | SanDisk Sansa e140 MP3 Player
Matsunichi MF326 MP3 Player Logo
3,763 people viewed this question
Top Matsunichi Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Matsunichi Audio Player and Recorder Expert? Answer questions, earn points and help others
