Question about Sanyo DS25390 TV
T.V. will not turn
I cannot get the tv to power up . the remote won't turn it on nor will the power switch on the the tv power it up, The tv is plugged into a working 110 outlet
The tv model no. is DS27225
The serial no. is V6310408166643
The tv is approx. 2 years old
  • zookeepr Dec 07, 2008
    press power and can hear set power up, about 5 seconds later hear a click (like a relay dropping out) and unit shuts down. it will do this 4 or 5 times and then wont do anything until it is unplugged for a couple of minutes, then does it all ove again. if using the remote it does the same thing.
  • 121 Answers
Try shocking  hit with open palm sides top. set on poss bad connnection. other wise prob not worth repair  sanyo has history of hor sweep circuit problems.
Posted on Dec 01, 2008
Tv power button
It seems that the micro-switch to turn on power is damaged. It can be replaced, and can be bought from most of the electronic spare part selling shops. De-solder out one among them as sample, because, pin configuration should be identified when you buy it. It wont cost more, a cheap component.
Jun 27, 2013 | Televison & Video
Tv won't turn on
This is a frustrating problem, but more details are required to solve it. Have you found the power switch on the TV? Are the batteries installed properly (facing the right way) in the remote? Is the TV connected to a working power circuit? If power is getting to the TV and the power switch doesn't work, I'd return the TV.
Mar 25, 2013 | JVC LT-46AM73 46 in. LCD HDTV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
New out of box tv won't come on, no lights no screen, tried several working outlets. can't turn on with remote or with button on tv
Look under the set or on the side for a Master Power Switch. If there is one turn it on. If not, take the set back and get it exchanged.
May 27, 2011 | AOC LE24H067 24 in. LCD TV
TV won't turn off
Or ironically the power switch on the TV could be stuck and causing a false on/off command. Don't let the simple things such as that be overlooked.
Dec 04, 2007 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
