Question about Motorola L3000
Motorola L6 battery won't charge, phone switches on and off continuously
Help. my phone will not charge when ever i use its charger. i charged the battery using an external/universal charger but the phone wouldn't still stay on even though the battery meter indicates that the battery is fully charged(switches on and off continuously).
4 Suggested Answers
  • 8 Answers
SOURCE: motorola l6 battry problem
You can with USB cable .
Posted on Dec 31, 2007
  • 7752 Answers
SOURCE: motorola L6 erratic ability to turn on
you need to take the phone to a mobile service center and have them reflash the firmware on the phone and that will correct the problem
Posted on Jan 16, 2008
  • 136 Answers
SOURCE: Motorola L6 Home charger
you may wanna try looking in the local gas stations they have car and home chargers for like 5 dollars where i live sounds like the charger you got with the company is faulty i would contact them and let them know and they should send you a prepaid box to send it back to them
Posted on Mar 17, 2008
  • 7752 Answers
SOURCE: Motorola L6 doesnt switch on
Take the phones to a mobile repair center and ahve them rectify the issues for you.
Posted on Jun 19, 2008
0 characters
1 Points
Motorola l6 but it turns on when the charger is plugged
Battery may be bad and may not hold a charge. Look for a replacement battery.
Motorola Support
Apr 23, 2014 | Motorola Mobility L6 Cellular Phone
Motorola l6 does not start up or switches on
The obvious here is, is the battery charged? Does your charger have an indicator light that comes on when plugged into the phone? Try to use your USB cable, connect it to your computer and then your phone. It should charge unless your battery is wasted. I would first ensure your charger is actually charging the battery. If that seems to be working, then check your battery to ensure it's good ( take it to your local phone store, they'll be able to tell you ). If the battery is bad, replace it. If the charger's bad, replace it. If neither is the problem, your phone would need to go to a repair shop. You can contact us for a repair estimate.
Nov 26, 2009 | Motorola Mobility L6 Cellular Phone
My L6 will not come on or charge up
i had that experience before. i was not able to charge my motorola l6, then i went to a cellphone repair shop then i ask the technician to shock my battery. and then it went up and get charged!
Mar 13, 2009 | Motorola Mobility L6 Cellular Phone
Motorola L6 charging?
get the right charger because that charger is not the right one okay
Sep 16, 2008 | Motorola Mobility L6 Cellular Phone
Motorola L6 Phone not charging or working
I solved the problem for my L6. IT appears that somehow the phone is software dependent. Meaning that you need to have the Motorola Software for the phone installed in your computer, connect the phone and voila! At least it solved my problem. All of a sudden it charged automatically and I can now charge with the power adapters too. (Yes I too went and bought a different charger, then when it didn;t worked I got a different battery..etc.) just give it a try. I think you can get it for free online somehow, just google it.
Jul 09, 2008 | Motorola Mobility L6 Cellular Phone
"invalid battery" and wont switch on
my motorola fon L6 is invelid battery plise find my recuest
May 27, 2008 | Motorola Mobility L6 Cellular Phone
Motorola l6
if you kept your mobile in charging for more than the phone needed. *********** board may be damaged. so immediately check *********** board is safe or not other wise your cell battery is damaged check it by replacing other battery,
May 20, 2008 | Motorola Mobility L6 Cellular Phone
Home Charger
do the chargers have the same pin or look the same?????
Mar 17, 2008 | Motorola Mobility L6 Cellular Phone
L6 Band IN London? charging problem
try a new battery.......if that does not help then change the mainboard....or have the phone reflash.
Dec 17, 2007 | Motorola Mobility L6 Cellular Phone
L6 won't charge
If u r not able charge u r battery , than change the charger , contact motorola care be u r not getting power supply in mobile
Oct 13, 2007 | Motorola Mobility L6 Cellular Phone
Cell Phones Logo
Top Motorola Cell Phones Experts
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
