put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Did you remove the rear cover and check for paper there? If it still shows a jam and there's absolutely no paper inside the printer, you may have to shut it off (or unplug it if it won't turn off), wait a few seconds, and turn it back on to clear the jam detection.
6A00 means the purge assembly is stuck, on the right where the printhead rests when turned off. impossible to clean without disassembly. Best to replace #qm2-3032-000, about $19.95
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
