Question about Zanussi 24 in. DA6153 Free-standing Dishwasher
Intermitant water fill ~ Zanussi di720 dishwasher
Have relocated dishwasher, it has been left standing for 2 months and since reconnecting it has not worked properly. I have had it filling on test, but as soon as I turn my back it fails to fill. Drain system is ok. Have looked at what I thought was inlet solenoid (thing the inlet hose connects to) but it seems to be a pressure bypass of some sort. Where is the inlet solenoid? any other suggestions? Thanks, Rob Boulton
5 Suggested Answers
  • 236 Answers
SOURCE: dishwasher
in some cases it is the water metering tank on the left hand side that gets bunged up and needs cleaning, next is the water feeding pipes. if everything is clean and the water valve supply is ok then it will need a special mod kit to be fitted, which will need to be fitted by a pro. tony.
Posted on Jun 16, 2007
maklean
  • 1665 Answers
SOURCE: zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Posted on Jan 12, 2008
  • 1003 Answers
SOURCE: Dishwasher not filling
I WOULD REPLACE SOLENOID AND TIMER
Posted on Jan 18, 2008
heatman101
  • 43501 Answers
SOURCE: Zanussi DW908 dishwasher will not
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Posted on Dec 07, 2010
My dishwasher will not fill with water
There can be multiple reasons why the water is not entering the line. First thing to do is to disconnect both hoses from the dishwasher and place them in the sink. Turn on the water slowly and make sure that both hoses release water into the sink. If the water flows, get a plastic drain snake and attempt to push it into the water intake lines from the rear of the dishwasher to clear any clogs that may be in the lines. Look at the rotary head in the dishwasher for hole clogs and remove any debris found. Reconnect the water lines and make sure that all inlet valves are open. Turn on the water and attempt the fill again. If this does not work, then you will have to disassemble the rear panel of the dishwasher and look closer at all waterline connections.
Mar 06, 2012 | Zanussi 24 in. DA6153 Free-standing...
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Beko dishwasher fills with water but then the pump doesn't kick in
hi there...this apliance emloys a flow meter..somtimes called a water meter...it is located on the bottom left hand side of the appliance it is accessible on removal of the left hand cabinet panel...disconnect and reconnect the plug to it...if this fails change the flow meter
regards Sir Galahad
Jun 27, 2009 | Beko 24 in. D3731F Free-standing...
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Zanussi da4342 dishwasher
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi dishwasher water input
it is possible but if you use a hot fill you will find that the rinse aid will produce a large amount of foam and the dishes wont dry properly
Dec 22, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Jun 10, 2007 | Zanussi 29 in. LS14 Free-standing...
Water will not fill into dishwasher
hi, it could be the inlet valve. This is usually what the hose fits to on the outside of the machine, and on the inside is the valve. MAKE SURE THE POWER IS OFF BEFORE you take the wires off the valve, then check for a reading on a ohms meter.ACROSS THE TWO TAGS, If no reading on the meter, the valve is gone. Regards, Tom.
Apr 06, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi 21 in. DCE5655 Free-standing Dishwasher
There is water in the bottom panel which has activated the float switch which overrides everything to stop the room the dishwasher is in from flooding. Remove the panel look for the leak. In my case one of the pipes had come off. There will be a lot of water in the panel so try and drain it first, tip the washer forward over some sort of container to catch the water. In my case I got very wet.
Jan 01, 2007 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi 24 in. DA6153 Free-standing Dishwasher Logo
44 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
