Question about Brother MFC-8460N All-In-One Printer
Paper mfc 8460n will not feed paper
    President:
  • Brother Master
  • 990 Answers
Open the top cover wherever your document feeding, you will see so many rollers use rubber rejuvenator to clean it.
Posted on Dec 13, 2008
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
May 21, 2014 | Brother MFC-8460N All-In-One Printer
IS REMPLACE PF KIT1
Tu peux poser ta question en francais... PF KIT stands for Paper Feed roller Kit, not Poulet Frit Kentuky LOL! you need to change the Paper Feed rollers...
Aug 10, 2011 | Brother MFC-8460N All-In-One Printer
What is a PF Kit 1?
hi
PF Kit 1, is the Paper Feeding Kit, number one.
http://www.retrevo.com/support/Brother-MFC-8460N-Multifunction-Printers-manual/id/260ag208/t/2/
User manual above.Below is your service and repair manual.
www.scribd.com/.../BROTHER-MFC8460n-Series-Service-Manual
Below is what the kit is for another type of printer to give you the idea.
Oct 08, 2010 | Brother MFC-8460N All-In-One Printer
It says to replace the PF Kit 1 what is that?
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
Aug 04, 2010 | Brother MFC-8460N Laser Printer
Problem for Brother MFC-8460N error message no paper in tray tried cleaning. re loading, on-off. etc.
Make sure the paper guide is not too tight, also set the paper tray on a table and look at the gear on the side at the bottom. The flat part of that gear must be level with the bottom of the tray, if not the metal under the lifter is bent and needs to be straightened. also tip the printer on it's back and make sure the sensor levers by the feed roller move freely.
Dec 24, 2009 | Brother MFC-8460N All-In-One Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
I have a brother 8460n. It wont feed the paper, the light turns red and it says no paper. There is a clicking noise when it tries to feed the paper through
pull cassette out and move the rear paper stopper away from rear of paper. leave about 1/8" gap. that should probably do it.
hth,
razors
Jan 10, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
121 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
