Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
Sony Trinitron Colour TV Model No. KV-24LS35U
The picture collapsed to a vertical line while the TV was showing and then turned to a black screen. The Starting-Switch-Light started to flicker periodically (10 flickers of red/green at about one second intervals followed by a green light for about 3 seconds and this event repeting itself at intervals of about 13 seconds). When the television is switched off and then on again the same event repeats itself at the same intervals.
Please advise me what may be the cause of this problem and suggessted remedies for it.
  • doundarsuphi Dec 03, 2008
    When the TV is switched on manually
    - No picture or sound come on.
    - The "Switch-Light" lights up green and then it blinks 11 times red. It then turns green and starts the same cycle all over again.
    1- What error does this code indicate? And
    2- If the Vertical Module (or any other IC/ Module) need to be changed where can I get it?
  • Anonymous Mar 27, 2014
    Television turns itself off
    Scholar:
  • 142 Answers
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Posted on Dec 01, 2008
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony 36" Trinitron
This is usually a vertical problem. If you can solder, try resoldering the vertical IC. If that fails, replace it. Report back with your results. The vertical IC is a small flat IC attached to a heat sink and will be marked LA7837 or something similar.
Dan
Aug 27, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY KV-XF21M80
maybe the bytes of the memory are not enough for this case^_^
Feb 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Colour distortion at the sides of the picture
check to see if you do not have speakers on the side of your tv or any where around it.which could be causing your problem.
Jun 09, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
258 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
