Question about Westinghouse SK-32H240S Television
Channel scan hangs and won't complete for cable input
I have Comcast digital cable tv  and use the cable box on another tv. On my westinghouse tv sk-32h240s I have the cable hooked in directly from the wall to the back of the tv. When I run the auto channel scan, it hangs after a while and will not complete.
Any help is appreciated.
SOURCE: Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Posted on Jan 28, 2009
SOURCE: Need a service manual for SK-32H240S TV
They are now sending me a new TV
Posted on Jun 03, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
SOURCE: SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Posted on Jul 09, 2009
westytech
  • 120 Answers
SOURCE: I have a westinghouse sk-32h240s power light is on
Hello, it seems like your LIPS board has gone out. This board has two parts to it, one is the power side which is still working (you still have power and sound), and the second part is the inverter side. This side of the board is responsible for powering on and off the backlight. When this goes out your unit is still functional with the exception that you cannot see the screen. The repair is easy if you are at least a bit technical. You will need to contact Westinghouse at 1800-701-0680 to order the LIPS board, once you have that you will need to open the unit, the LIPS board is immediately visible, you remove the part and replace it with the new one and your TV is now functional. You can send me a quick email at westytech@wde.com if you need any sort of assistance. Please rate my help on this site.
Posted on Apr 23, 2010
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Tv setup - cannot get past auto channel
Connect the TV to the Comcast box using an HDMI cable, then set input on the TV to HDMI - that's all. You then select channels on the Comcast box , not the TV (although the TV remote can be programmed to change channels on the cable box)>
Jan 27, 2014 | Element Televison & Video
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
Jan 04, 2014 | Westinghouse Televison & Video
Setup wizard
what do i do fix this ?
Dec 06, 2013 | Westinghouse Televison & Video
Have a curtis tv , trying to run autoscan, it runs, but it doesn't locate any channels. I have a comcast converter box also. Not sure why autoscan isn't working. Or do I have to set up my comcast...
For the auto scan to detect there must be channels present on the CABLE that is connected to the RF input- TUNER INPUT- of the TV.
So check with your cable operator for the channels and you can connect. however if you are using a digital box then the channels are memorised on the box as only the output of the box is connect to the video/audiop inputs of the TV. if so select line in/video 1/2.
Oct 18, 2011 | Curtis 326A LCD TVDVD Combo
The local cable company has gone digital and now my westinghouse lcd tv sk-19h210s only gets 24 channels. How do I do a channel scan?
Hi, You need a analog and digital tuner in the TV, which it sounds like you don't have, or a digital cable box.
Jun 15, 2011 | Westinghouse SK-19H210S Television
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Audio but scrambled picture with coax cable on lcd tv
if your tv is component compatable meaning is there a red green and blue connection at the back this is the way to connect to hi defenition.these leads are sold in game. give this a try youll luve the picture too.
May 17, 2009 | Microsoft Xbox 360 Console
Digital conver. on 2/17/2009
This TV comes with a dual tuner uhf/vhf in and digital antenna in .hook to digital antenna input and change input on remote to dtv hit menu and let it scan for channels.
Nov 15, 2008 | Sanyo HT32546 TV
Televison & Video Logo
124 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
