Question about Seiko VR5000 Dictionary
Memory is corrupted, please press any key, data will be lost
I press "up or down" , show a message: "initializing" , and after 10 minutes show: SST29EE020 ( 1 X 2M) FLASH ID: 10BF PROGRAM VER: 0100 PATCH SIZE: 000000000H [UP/DOWN] patch size[enter] save and exit. I put batteries again and the first mesagge appear again, and again, even if I reset this dicctionary. thanks for your time, please reply if I could repair somewhere, and how much could be this service.
0 characters
1 Points
Sharp zq 700
Try removing the batteries for a couple minutes and try again. Maybe try different set of batteries.
Dec 29, 2013 | Electronic Dictionaries & Translators
It does nothing
Yes. You should never remove the card while it's on - certainly not while it's starting up. I'm almost certain it was writing something to the card when you removed it, and now the data on it is corrupted. You'll have to either replace the card, or contact Ectaco to have them reprogram it.
Dec 22, 2007 | Ectaco E15K800 Dictionary / Translator
Sharp zq1400a
Only option is to Clear the memory.
Sep 11, 2013 | Electronic Dictionaries & Translators
I have the Merriam-Webster® Speaking Dictionary & Thesaurus (MWS-1840) The screen is erratic. I tried to push clear at the same time as the on/off button, but nothing happened. So I...
If the screen performs eratically, then the only way is resetting the bookman, here is the exact procedure for resetting the Bookman,
Follow these exact steps for performing the soft reset:
1)First Press the clear button and press the ON/OFF button twice..
If this soft reset procedure doesnt work, then try hard reset..
Warning: Doing a hard reset will delete all the setting saved by you..
Here is the procedure for performing hard reset..
1)Hold CLEAR and ON/OFF button for 5-10 seconds, this should perform a hard reset, if you still have issue, follow the next step
2)Use paperclip and gently press the RESET button,
Reset button is present in a pin hole sized block present at the backside of the bookman
Any of the following procedure should solve your issue
Please leave me comment, if you need further assistance
Rnj VinodKumar
Jan 31, 2010 | Franklin Electronic Dictionaries &...
Viewing conjugations
Check page 10 of the manual, you can download from here (English and Spanish version):
Aug 04, 2009 | Franklin Talking Spanish-English Student...
Zelco Bookmark dictionary II cannot change clock to from AM to PM
Are you in the 12 hour or 24 hour format?
Start here:
-Press the little clock icon (it's above the letter "Q")
-Press the "A" key to toggle between 12 and 24 hour mode. Sometimes I have to do it a couple times to make sure I know exactly which mode it's in.
-Press the "Space" key to enter time setting mode.
- Use your number pad to enter the time...
- Press "ENTER" key to confirm. It will then take you to the Date Setting Mode. If your date is already set just press "ENTER" again.
I think that should help. If not, let me know.
Please rate as a FIX YA if I helped. ;-)
Feb 01, 2009 | Zelco 90112 Bookmark Dictionary II
Lost password to the data section & how to hard reset the device
just take out the batteries and leave them out for a minute or two and everything will reset.
Jan 10, 2009 | Franklin MWD-1470 Webster's Dictionary...
Only 22 minutes of recording time?
it is possible that you may want to reset the device and erase all of the data from it - seems as if the memory is caching some of the data that you thought was erased.
To reset the device - press the stop and erase button at the same time and clear should be on the screen - select yes and press enter - the device should now give you the maximum recording time allowed
Nov 30, 2008 | Olympus VN-900 Digital Voice Organizer
User's Manual
For the manual ask at
They will find it.
Oct 19, 2007 | Electronic Dictionaries & Translators
Seiko VR5000 Dictionary Logo
16 people viewed this question
Top Seiko Electronic Dictionaries & Translators Experts
Richard Roth
Richard Roth
Are you a Seiko Electronic Dictionary and Translator Expert? Answer questions, earn points and help others
